DXS-3600-16SEOL
10GB L2/L3 lüliti, 8 fikseeritud SFP+ 10G porti
Kirjeldus
D-Link’s DXS-3600 10GbE L2/L3 Switch family consist of new compact, high-peformance switches that feature wired-speed 10-Gigabit Ethernet switching, routing, and very low latency. The 1U height and selectable front-to-back or back-to-front air flow make the DXS-3600 series suitable for top-of-rack (ToR) deployment in data centers or enterprise and campus aggregation network environments. The DXS-3600 switches have 24 fixed 10 GbE SFP+ ports and can feature more ports with the addition of an expansion module. The expansion modules not only provide extra 10G SFP+ ports, but also increase the flexibility of 120G stacking, 40G uplinks or low cost inter-rack 10G Base-T connections for different applications.
The DXS-3600 switches deliver high-performance 10-Gigabit Ethernet switching capacity of up to 960 Gbps and forwarding rates of up to 595.2 Mpps. The switches feature hot-swappable power supplies and fan trays, which enable the switches to be a redundant, high availability architecture. The modular power design allows users to select AC or DC power according to where the switch is deployed. When inserting two power modules, the two power modules share the loading and help to extend the lifetime of the other. The DXS-3600 series also features a modular fan design. Three fans can back up each other, providing N+1 redundancy for the system. If one of the fans fails, the other fans will increase their speed by automatically detecting the system temperature. Both power and fan modules are hot-swappable, which minimizes the downtime of the DXS-3600 series.
Standard and Enhanced Images
The DXS-3600 switches provides two different software images. The Standard Image (SI) features a wide range of Layer 2, VLAN, multicasting, Quality of Service (QoS), security, data center, and static routing functions. The Enhanced Image (EI)  features comprehensive IPv4/v6 routing including RIP, VRRP, OSPF, BGP, and L3 multicasting like IGMP, MLD, PIM-DM, SM, SDM, SSM, and DVMRP. The EI also supports L2/L3 MPLS VPN that enables the DXS-3600 series switches to also be deployed as the core router of an enterprise environment or an edge router of a MPLS environment.
Data Center Features
Data Center Bridging (DCB) is an essential set of enhancements to Ethernet for networking in data center environments. The DXS-3600 switches support several core components of Data Center Bridging (DCB) such as IEEE 802.1Qbb1*, IEEE 802.1Qaz1*, and IEEE 802.1Qau*.  IEEE 802.1Qbb (Priority Based Flow Control) provides flow control to ensure there is no data loss during network congestion. IEEE 802.1Qaz (Enhanced Transmission Selection) manages the allocation of bandwidth amongst different traffic classes. IEEE 802.1Qau (Congestion Notification) provides congestion management for data flows within network domains to avoid congestion. The DXS-3600 switches also support cut-through switching, which reduces latency in transmitting data in a network.
Energy Efficient
The DXS-3600 switches allow users to change the airflow by using different power and fan module sets. Selectable front-to-back or back-to-front airflow maximizes air cooling to provide more effective cooling throughout rack systems in data centers, where the switches are used, compared to side-to-side airflow. The switches also feature built-in smart fans; internal heat sensors monitor and detect temperature change, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run slower and reduce the switch’s power consumption and noise.
Põhiomadused
Liides
8 fikseeritud 10GB porti, laiendusmooduli lisamisvõimalusega
Konsooliport
RJ-45 out-of-band juhtimiseks
Juhtimisport
10/100/1000 Base-T RJ-45 out-of-band juhtimiseks
SD-kaardipesa
1
Jõudlus
• Switching capacity : 480 Gbps
• Max. Forwarding Rate: 357.14 Mpps
• Packet Buffer Memory: 9 МB
• MAC Address Table: 128K
Stackability
• Virtual Stacking/Clustering of up to 16 Units*
  - Supports D-Link Single IP Management
L2 Features
• ƒMAC Address Table
  - 128K entries
• Flow Control
  - 802.3x Flow Control when Full Duple
  - Back Pressure when Half Duplex
  - HOL Blocking Prevention
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - Support Root Restriction
• Loopback Diagnostics*
• 802.1AX Link Aggregation
  - Max. 16 groups per device, 12 ports per group
• ERPS*  (Ethernet Ring Protection Switching)
• Port Mirroring
  - Supports One-to-One, Many-to-One
  - Supports Mirroring for Tx/Rx/Both
  - Supports 4 mirroring groups
• Flow Mirroring
  - Supports One-to-One,Many-to-One
  - Supports Mirroring for Rx
• Jumbo Frame
  - Up to 12,000 bytes
L2 Multicast Features
• IGMP Snooping
  - IGMP v1/v2/v3 Snooping
  - Supports 4K IGMP groups
  - Supports 1K static multicast addresses
  - IGMP per VLAN
• L2 Multicast Filtering
  - Forwards all groups
  - Forwards all unregistered groups
  - Filters all unregistered groups
ƒ• MLD Snooping*
  - MLD v1/v2 Snooping
  - Support 4K groups
  - Host-based MLD Snooping Fast Leave
VLAN
•ƒ 802.1Q
•ƒ 802.1v
•ƒ Double VLAN (Q-in-Q)
  - Port-based Q-in-Q
  - Selective Q-in-Q
•ƒ Port-based VLAN
• ƒMAC-based VLAN
•ƒ Subnet-based VLAN
•ƒ Private VLAN2
•ƒ VLAN Group
  - Max. 4K static VLAN groups
  - Max. 4094 VIDs
•ƒ GVRP
  - Up to 4K dynamic VLANs
QoS (Quality of Service)
•ƒ 802.1p Quality of Service
•ƒ 8 queues per port
•ƒ Queue Handling
  - Strict
  - Weighted Round Robin (WRR)
  - Strict + WRR
  - Round Robin (RR)
  - Weighted Elastic Round Robin (WERR)
•ƒ CoS based on
  - 802.1p Priority Queues
  - DSCP
  - IP address
  - MAC address
  - VLAN
  - IPv6 Traffic Class
  - IPv6 flow label
  - TCP/UDP port
•ƒ Bandwidth Control
  - Port-based (Ingress/Egress, min. granularity 8 Kb/s)
  - Flow-based (Ingress/Egress, min.granularity 8 Kb/s)
  - Per queue bandwidth control (min. granularity 8 Kb/s)
•ƒ Three Color Marker
  - trTCM
  - srTCM
•ƒ Congestion Control
  - WRED
•ƒ Support for following actions:
  - Remark 802.1p priority tag
  - Remark TOS/DSCP tag
  - Bandwidth Control
  - Committed Information Rate (CIR)
L3 Features (SI version)
• ARP
  - 512 Static ARP
  - Supports Gratuitous ARP*
•ƒ IP Interface
  - Supports 256 interfaces
  ƒ Loopback Interface*
L3 Routing (SI version)
•ƒ Default Routing
•ƒ Static Routing
  - Max. 1K IPv4 entries
  - Max. 512 IPv6 entries2
  - Support route distribution
  - Support secondary route
  - Support Equal Cost/Weighted Cost multi-path route
Access Control List (ACL)
•ƒ ƒMax. ACL entries:
  - 1792 ingress ACL rule
  - 1K egress ACL rules
  - 1K VLAN ACL rules
•ƒ Time-based ACL
•ƒ ACL based on:
  - 802.1p priority
  - VLAN
  - MAC address
  - Ether type
  - IP address
  - DSCP
  - Protocol type
  - TCP/UDP port number
  - IPv6 flow label
Security
•ƒ Port Security
  - Supports up to 12K MAC addresses per port/system
•ƒ Broadcast/Multicast/Unicast Storm Control
•ƒ D-Link Safeguard Engine*
•ƒ DHCP Server Screening*
•ƒ IP-MAC-Port Binding*
  - ARP inspection
  - IP inspection
  - DHCP Snooping
•ƒ ARP Spoofing Prevention*
  - Max. 64 entries
  ƒ Traffic Segmentation
•ƒ SSL*
  - Supports v1/v2/v3
  - Supports IPv4/v6 access
  ƒ SSH
  ƒ BPDU Attack Prevention
  ƒ DOS Attack Prevention
AAA
•ƒ 802.1X Authentication
  - Supports Port-based access contro
  - Supports Host-based access contro
  - Dynamic VLAN Assignment
  - Identity-driven Policy  (VLAN/ACL/QoS) Assignment
•ƒ ƒWeb-based Access Control (WAC)*
•ƒ ƒMAC-based Access Control (MAC)*
•ƒ Guest VLAN
MIB & RFC Standards
•ƒ RFC1213 MIB II
•ƒƒ RFC1907 SNMP v2 MIB
•ƒƒ RFC5519 IGMP v3 MIB
•ƒƒ RFC1724 RIP v2 MIB
•ƒƒ RFC2021 RMONv2 MIB
•ƒƒ RFC1643, RFC2358, RFC2665 Ether-like MIB
•ƒƒ RFC2668 802.3 MAU MIB
•ƒƒ RFC2674 802.1p MIB
•ƒƒ RFC2618 RADIUS Authentication Client MIB
•ƒƒ RFC2096 IP Forwarding Table MIB
•ƒƒ RFC2932 IPv4 Multicast Routing MIB
•ƒƒ RFC2934 PIM MIB for IPv4
•ƒƒ RFC2620 RADIUS Accounting Client MIB
•ƒƒ RFC2925 Trace Out MIB
•ƒƒ RFC2925 Ping MIB
•ƒƒ RFC1850 OSPF MIB
•ƒƒ Private MIB
•ƒƒ RFC1112, RFC2236, RFC3376, RFC4541 IGMP Snooping
•ƒƒ RFC4363 802.1v
•ƒƒ RFC2338 VRRP
•ƒƒ RFC1058, RFC1388, RFC1723, RFC2453, RFC2080 RIP
•ƒƒ RFC1370, RFC1765, RFC2328, RFC2740, RFC3101 makes RFC1587 obsolete, RFC2328 makes RFC1583, RFC2178 OSPF v2,v3
•ƒƒ RFC1771, RFC1997, RFC2439, RFC2796, RFC2842, RFC2918 BGP
•ƒƒ RFC3973 PIM-DM
•ƒ RFC5059 PIM-SM
•ƒƒ RFC3569, RFC4601, RFC4608, RFC4607, RFC4604 PIM SSM
•ƒƒ RFC3376 IGMP
•ƒƒ RFC2475 Priority Queue Mapping
•ƒƒ RFC2475, RFC2598 Class of Service (CoS)
•ƒƒ RFC2597, RFC2598 QoS Flow Actions
•ƒƒ RFC2697, RFC2698 Three Color Marker
•ƒƒ RFC2093, RFC2904, RFC2095, RFC2906 AAA
•ƒƒ RFC1321, RFC2144, RFC2313, RFC2420, RFC2841, RFC3394 Encryption
•ƒƒ RFC2289 One-Time
•ƒƒ RFC3580 802.1X
•ƒƒ RFC2866 RADIUS Accounting
•ƒ RFC2138, RFC2139, RFC2865, RFC2618 RADIUS Author. for Management Access
•ƒƒ RFC1492 TACACS+ Auth. for Management Access
Sertifikaadid
Sidustooted
Pildid
DXS-3600-16S/B
Eestvaade
Tagantvaade
Failid
Vaadake samuti
