DEM-CB300CXEOL
10G InfniBand Twinaxial Cables, 3m
Kirjeldus
	The InfniBand Cable Series 10G InfniBand Twinaxial Cables are designed to support high-speed connections for 10Gbps Ethernet devices1. The series consists of fve models: the DEM-CB50, DEM-CB100, DEM-CB300, DEM-CB50ICX, and DEM-CB300CX. The 10G InfniBand Twinaxial Cables are an ideal solution for cost-effective, high-speed networking connectivity between D-Link switches, and other devices within a rack or in adjacent racks.
	Ideal for High-Bandwidth Operation
	The D-Link 10G InfniBand Twinaxial Cables support speeds of up to 10Gbps over distances of up to 3metres. This 10GBASE-CX4 cabling runs over four pairs of twinaxial copper wiring, resulting in low latency, and supports the InfniBand fabric’s quality of service (QoS) and failover features. The result is an optimal solution for handling high bandwidth transmission over short distances.
	10GBASE-CX4 Connectors
	The 10G InfniBand Twinaxial Cables use 4X InfniBand connectors with screw or latch type plugs. The DEM-CB50, DEM-CB100, and DEM-CB300 feature screw-type connectors at both ends, and can be used as physical stacking cables or uplink cables for D-Link’s DGS-3120 L2 Managed Stackable Gigabit Switch series. The DEM-CB50ICX features a screw-type connector at one end for connection to the DGS-3120 series, and a latch-type connector at the other end for connection to the DMC-805X media converter. The DEM-CB300CX features a latch-type connector at both ends and can be used as a physical stacking cable for the DGS-3400 Series Advanced Layer 2+ Gigabit Switches and the accompanying DEM-410CX module.
	1 It is recommended that the 10G InfniBand Twinaxial Cables are only used with D-Link products.
Põhiomadused
	Connector Type
	Latch-type at both ends
	Cable Length
	300cm
	Wire AWG
	28AWG
	Connectivity
	Physical stacking cable for linking DGS-3400 series with DEM-410CX (recommended)
Sertifikaadid
Sidustooted
DEM-CB300CX 10G InfniBand Twinaxial Cables, 3m
