DEM-211EOL EOS
SFP Transceivers 1 port 100Base-FX for singlemode fiber optic cable, power supply 3.3V (up to 2km)
Kirjeldus
D-Link's DEM-210 and DEM-211 SFP transceivers provide a high performance solution for serial optical data communication applications. They are hot-swappable, Small Form Factor Pluggable (SFP) compliant with the Multi-Source Agreement (MSA) specification. The transceivers have duplex LC connectors and provide IEEE 802.3u compliant link for up to 100Mbps in the half duplex mode (or 200Mbps full-duplex mode) transmission for fiber cable applications.
D-Link's highly integrated transceivers offer low jitter performance for extended optical links support without performance degradation. This high performance enables reliable data transfer in short-, intermediate- and long-distances for building, factory, campus and metropolitan networking applications.
Previous combo-port switch designs have only provided Gigabit copper or SFP fiber-optic connectivity but not 100BASE-FX SFP fiber-optic connectivity. Switch designs like the DES-1226G and DES-3526 are of the former type.
D-Link now provides 100BASE-FX SFP fiber-optic connectivity on Gigabit combo SFP ports for new switch model designs1.
1 The current list of D-Link switches that support the new module includes the following: DES-1228, DES-1228P, DES-1252, DHS-3028, DHS-3628F, DHS-3626F, DGS-3612G.
Põhiomadused
Cable
Single-Mode Fiber
Fiber Type
62.5/125um Single-Mode
Max. Cable Distance
2 km
Standard
802.3u 100BASE-FX
Data Rates
100Mbps
Port Type
Duplex LC
RoHS Compliant
Wavelength
1310nm
Output Optical Power
Max. -14dBm, Min. -19dBm
Sensitivity
-32dBm
Power Budget
13dB
Power Voltage
3.3V
Operating temperature
0 to 70°C
Storage humidity
-40 to 85°C
MTBF (hours)
3259763
Dimensions
13.4x 56.4 x 10.35мм
Weight
0.0164kg
Emission
FCC Class B, CE, ICES-003, VCCI
Safety
FDA/CDRH, TUV, UL
Sertifikaadid
Sidustooted
DEM-211/10 SFP Transceivers 1 port 100Base-FX for singlemode fiber optic cable, power supply 3.3V (up to 2km)
