Kiirotsing
Toote omadused:
8-port 10GBASE-T and 2-port SFP+ and 2-port 10GBASE-T/SFP+ combo design Smart Switch
EOL
Põhiomadused:
Interfaces
• 8-port 10GBASE-T
• 2-port SFP+
• 2-port 10GBASE-T/SFP+ combo design
Port Standard and Functions
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• IEEE 802.3az compliance
• IEEE 802.3an 10GBASE-T 10GbE over copper
• IEEE 802.3ae 10GbE over fiber
• IEEE 802.3z 1000BASE-X
• Auto MDI/MDIX support for 1000/10GBASE-T
Network Cables for 10GBASE-T
• CAT-6 (30 m max)
• CAT-6A or CAT-7(100 m max)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all twisted-pair ports
Performance
Switching Capacity
• 240 Gbps
Maximum Packet Forwarding Rate
• 178.56 Mpps
Transmission Method
• Store-and-forward
MAC Address Table
• Up to 16,000 entries per device
Software
L2 Features
• MAC Address Table
  • Up to 16K entries
• Static MAC Addresses
  • 1K
• IGMP Snooping
  • IGMP v1/v2/v3 Snooping
  • Supports 1000 IGMP groups
  • Supports at least 128 static multicast addresses
  • Per VLAN IGMP Snooping
  • Support host-based fast leave
• MLD Snooping
  • MLD v1/v2 Snooping
  • Support 1000 groups
  • Support 128 static multicast addresses
• LLDP
• LLDP-MED
• Spanning Tree Protocol
  • 802.1D STP
  • 802.1w RSTP
  • 802.1s MSTP
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• Port Mirroring
  • One-to-One
  • Many-to-One
  • Supports Mirroring for Tx/Rx/Both
• 802.3ad Link Aggregation:
  • Maximum of 8 groups/8 ports per group
 • Jumbo Frame
  • Up to 9KB
• Loopback Detection
• ERPS (Ethernet Ring Protection Switching) 1
VLAN
• 802.1Q VLAN
• Port-based VLAN
• 4K VLAN Groups
• Configurable VID
  • 1~4094
• Voice VLAN1
• Auto Surveillance VLAN1
• GVRP1
• Asymmetric VLAN
Quality of Service (QoS)
• CoS based on
  • 802.1p Priority Queues
  • DSCP
  • ToS
  • IPv6 Traffic Class
  • TCP/UDP port
  • VLAN ID
  • MAC Address
  • Ether Type
  • IP Address
  • Protocol Type
  • IPv6 Flow Label
• 8 queues per port
• Queue Handling
  • Strict
  • Weighted Round Robin (WRR)
  • Deficit Round Robin (DRR)
  • Weighted Deficit Round Robin (WDRR)
• Bandwidth Control
  • Port-based (Ingress/Egress, min. granularity 64 Kbps)
L3 Features
• IP Interface
  • Supports 16 IPv4/v6 interfaces
• ARP
  • 128 Static ARP
• Default Route1
• Static Route1
  • Max. 32 IPv4 entries
  • Max. 32 IPv6 entries
Access Control List (ACL)
• Max. 512 access list
• Max. 512 ACL rules
• Max. 50 VLAN access map1
• ACL based on
  • 802.1p priority
  • VLAN1
  • MAC address
  • Ether type
  • IP address
  • DSCP
  • Protocol type
  • TCP/UDP port number
  • IPv6 flow label
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• DHCP Server Screening
• IP-MAC-Port Binding
  • DHCP Snooping1
  • IP Source Guard1
  • Dynamic ARP Inspection1
  • IPv6 Snooping1
  • IPv6 Source Guard1
  • DHCPv6 Guard1
  • IPv6 ND Inspection1
  • IPv6 Route Advertisement (RA) Guard1
• Traffic Segmentation
• SSH1
  • Support v1/ v2
  • Support IPv4/ IPv6
• SSL
  • Support v1/v2/v3
  • Support IPv4/IPv6
• ARP Spoofing Prevention1
  • Max. 127 entries
• DoS Attack Prevention
• Port Security
  • Supports up to 64 MAC addresses per port
• Duplicate Address Detection
OAM
• Cable Diagnostics
AAA
• Web-based Access Control (WAC)1
  • Support local/RADIUS database
  • Support Port-based access control
  • Support Host-based access control
  • Support Dynamic VLAN Assignment
  • Identity-driven Policy (VLAN/ACL/QoS) Assignment
• 802.1X Authentication1
  • Supports local/RADIUS database
  • Supports Port-based access control
  • Supports Host-based access control
  • Supports EAP, OTP, TLS, TTLS, PEAP
• Support IPv4/IPv6 RADIUS Server1
• Support IPv4/IPv6 TACACS+1
• Guest VLAN1
• Compound Authentication1
• Authentication for management access
• Authentication Database Failover1
• MAC-based Access Control (MAC)1
Management
• Web-based GUI
• D-Link Network Assistant Utility
• Compact CLI
• Telnet Server
• TFTP Client
• Configurable MDI/MDIX
• SNMP
  • Supports v1/v2c/v3
• SNMP Trap
• Smart Wizard
• LLDP
• LLDP-MED
• DHCP Relay1
• System Log
• BootP/DHCP Client
• SNTP1
• ICMP v6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration1
• RMON v1/v21
• Trusted Host
• Dual Images
• Dual Configurations1
• DNS Client1
• Debug command
Green V3.0 Technology
• Power Saving by:
  • LED Shutoff
  • System Hibernation
  • Port Shutoff
MIB/RFC Standards
• RFC 783 TFTP
• RFC 951 BootP/DHCP Client
• RFC 1157 SNMP v1, v2, v3
• RFC 1213 MIB II
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1769 SNTP
• RFC 1542 BootP/DHCP Client
• RFC 1901 SNMP v1, v2, v3
• RFC 1907 SNMP v2 MIB
• RFC 1908 SNMP v1, v2, v3
• RFC 2131 BootP/DHCP Client
• RFC 2138 RADIUS Authentication1
• RFC 2139 RADIUS Authentication
• RFC 2233 Interface Group MIB
• RFC-2246 SSL
• RFC 2475
• RFC 2570 SNMP v1, v2, v3
• RFC 2575 SNMP v1, v2, v3
• RFC 2598 CoS
• RFC 2618 RADIUS Authentication1
• RFC 2819 RMON v1
• RFC 2865 RADIUS Authentication
• RFC 3164 System Log
• RFC 3195 System Log
• RFC 3411-17 SNMP
• D-Link Private MIB
• LLDP MIB
• Zone Defense MIB
• 2233 Interface Group MIB
Physical/Environmental
AC Input
• 100 to 240 VAC
Maximum Power Consumption
• 90.81 watts
Standby Power Consumption
• 42.65 watts
Operating Temperature
• -5 to 50 °C (23 to 122 °F)
Storage Temperature
• -40 to 70 °C (-40 to 158 °F)
Operating Humidity
• 0 % to 95 % non-condensing
Storage Humidity
Dimensions (L x W x H)
• 440 x 210 x 44 mm (17.36 x 8.26 x 1.73 inches)
Weight
• 3.15 kg
Diagnostic LEDs
• Link/Activity/Speed (Per 10GBASE-T port)
• Link/Activity/Speed (Per 10G SFP+ port)
• Power/Fan (Per device)
Certifications
• CE
• FCC
• C-Ticket
• VCCI
• BSMI
• CCC
Safety
• cUL
• CB
• CE
• CCC
• BSMI
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
