Kiirotsing
Toote omadused:
Managed L2 Metro Ethernet Switch
Põhiomadused:
Hardware Version
• A1
Size
• 190 x 120 x 38 mm (7.48 x 4.72 x 1.50 inches)
Number of Ports
• Five 10/100/1000BASE-TX ports
• One 100/1000 SFP port
Performance
Switching Capacity
 • 12 Gbps
64-byte Maximum Forwarding Rate
 • 8.9 Mpps
MAC Address Table Size
• 4K Entries
SDRAM for CPU
• 128 MB
Packet Buffer
• 128 KB
Flash Memory
• 16 MB
Jumbo Frame
• 9216 Bytes
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
Power Consumption
• Standby Mode: 3.62 watts
• Maximum: 7.08 watts
Software Features
L2 Features
• MAC Address Table: 4K
• 802.3x Flow Control
• HOL Blocking Prevention
• Loopback Detection
• Port Mirroring
• Supports one mirroring group
• One-to-One
• Many-to-One
L2 Multicasting
• IGMP Snooping
• IGMP v1/v2 Snooping, v3 Awareness
• Supports 32 Groups
• Port-based IGMP snooping Fast Leave
• IGMP Authentication
• Limited IP Multicast
• MLD Snooping
• MLD Snooping v1, v2
• Supports 32 MLD Snooping groups
• Port-based MLD Snooping Fast Leave
VLAN
• 802.1Q Tagged VLAN
• VLAN Group
• Supports 32 static VLAN groups
• Management VLAN
• Port-based VLAN
• ISM VLAN
• Double VLAN (Q-in-Q)
• Port-based Q-in-Q
Quality of Service (QoS)
• 4 queues per port
• Queue Handling
• Strict Priority
• Weighted Round Robin (WRR)
• Bandwidth Control
• Port-based (Ingress/Egress, min. granularity 64 Kb/s)
• CoS Based on:
• 802.1p
• DSCP
• IPv6 Traffic Class
Security
• Port Security
• Up to 64 MAC addresses per port
• Traffic Segmentation
• Broadcast/Multicast/Unknown Unicast Storm Control
• D-Link Safeguard Engine
AAA
• 802.1X
• Port-based Access Control
• Host-based Access Control
• Supports Guest VLAN
• Support Local/RADIUS Servers
• Support RADIUS Accounting
• 4 Levels of User Accounts
OAM
• Cable Diagnostics
• 802.3ah
Management
• Web-based GUI
• Command Line Interface (CLI)
• Telnet Server
• TFTP Client
• SNMP v1/v2c/v3
• SNMP Traps
• System Log
• RMON v1
• Support 1,2,3,9 Groups
• LLDP
• BootP/DHCP Client
• DHCP Auto-Configuration
• DHCP Relay for IPv4/IPv6
• DHCP Relay Option 82
• DHCP Relay Option 37
• PPPoE Circult-ID Tag Insertion
• SNTP
• CPU Monitoring
• Password Encryption
MIB
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2233, 2863 IF MIB
• Private MIB
IETF Standard
• RFC768 UDP
• RFC791 IP
• RFC792,2463, 4443 ICMPv4
• RFC793 TCP
• RFC826 ARP
• RFC 2474, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
• RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
• RFC1981, RFC2460, RFC2461,4861, RFC2462,4862, RFC2464, RFC3513,4291, RFC2893,4213
Physical
Power Input
• External Power Adapter: 100 to 240 V AC, 50 to 60 Hz
• Output: 12 V/1 A
MTBF
• 459,420 hours
Acoustics
• 0 dB
Heat Dissipation
• 24.16 BTU/hr
Weight
• 0.42 kg (0.925 pounds)
Ventilation
• Fanless
Operating Temperature
• 0 to 40 °C (32 to 104 °F)
Storage Temperature
• -40 to 70 °C (-40 to 158 °F)
Operating Humidity
• 10% to 90%
EMI
• CE Class A
Safety
• CE LVD, UL/cUL
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
