Kiirotsing
Toote omadused:
26-Port Unmanaged Gigabit PoE Switch
Põhiomadused:
Number of Ports
• 24 x 10/100/1000 Mbps ports
• 2 x 10/100/1000BASE-T/SFP combo ports
Standards
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• IEEE 802.3z
• IEEE 802.3x Flow Control
• IEEE 802.3az Energy Efficient Ethernet (EEE)
Switching Capacity
• 52 Gbps switching fabric
64 Byte Max. Forwarding Rate
• 38.69 Mpps
Media Interface Exchange
• Auto MDI/MDI-X
Transmission Method
• Store-and-forward
MAC Address Table
• 8K (8192) entries per device
Packet Buffer Memory
• 512 KB per device
PoE Standards
• IEEE 802.3at
• IEEE 802.3af
PoE Ports
• Ports 1 to 24
PoE Budget
• 370 W
• Up to 30 W per port
LEDs
Per Unit
• Power
• PoE Power Budget
Per Port
• Activity/Link
• Speed
Per PoE Port
• Power Fail
• Power OK
Physical Parameters
Fan
• 2 x Smart fans
Dimensions
• 440 x 250.4 x 44 mm
Weight
• 3.1 kg
Power Input
• AC Input: 100 to 240 V AC, 50/60 Hz
Power Consumption
Maximum:
• 444.1 W (PoE on)
• 82.1 W (PoE off)
Standby:
• 100 V: 18.35 W
• 240 V: 18.25 W
Temperature
• Operating: 0° to 50°C
• Storage: -40° to 70°C
Humidity
• Storage: 5% to 90% non-condensing
MTBF
• 205,975 hours
Heat Dissipation
• 1,515 BTU/h
EMI
• FCC Class A
• CE
• CCC
• RoHS
• VCCI
• BSMI
• RCM
Safety
• UL/CSA 60950-1
• EN 60950-1
• IEC 60950-1
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
