DGS-3630-28TCProjektideks
20 10/100/1000BASE-T ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with MPLS Image
Kirjeldus
	The DGS-3630 Series Layer 3 Stackable Managed Switches are a range of switches designed for Small Medium Businesses (SMBs), Small Medium Enterprises (SMEs), enterprises, and ISPs. They deliver high performance, flexibility, fault tolerance, and advanced software features for maximum return on investment. With Gigabit Ethernet SFP, 10 GbE SFP+, security features, and advanced Quality of Service (QoS), the DGS-3630 Series can act as core, distribution or access layer switches. High port densities, switch stacking, and easy management make the DGS-3630 Series suitable for a variety of applications.
	Standard, Enhanced, and MPLS Images
	The DGS-3630 Series is designed for use with three different software images: the Standard Image (SI), the Enhanced Image (EI), and the MPLS Image (MI). The Standard Image provides core SMB and SME functionality, such as L2 switching, entry-level routing, L2 multicast, advanced QoS, Operations, Administration, and Maintenance (OAM), and robust security features. The Enhanced Image supports full L3 routing for enterprise integration, including OSPF, BGP, VRF-Lite and L3 multicast. The MPLS Image offers VPN services for ISPs, including IS-IS and MPLS L2/L3 VPN. With multiple software images, only the required features need to be installed, providing a flexible approach to software management.
	High Availability and Flexibility
	The DGS-3630 Series includes stacking technology, which allows multiple switches to be combined to form a single physical or virtual stack. This increases redundancy over multiple physical units, simplifies management, and provides a single IP address to manage all members in the stack. Up to 9 switches can be combined using Direct Attach Cables to make up to 432 Gigabit Ethernet ports available, allowing switching capacity to be increased with demand. The Switch Resource Management (SRM) feature allows the hardware table size to be changed, so that switch functions can be optimized based on the use of the switch. There are 3 modes: IP Mode, LAN Mode, and L2 VPN Mode, which modify the size of the Layer 2 and 3 tables for optimum efficiency.
	Security, Performance & Availability
	The DGS-3630 Series provides a complete set of security features including multi-layer Access Control Lists (ACLs) and 802.1X user authentication via TACACS+ and RADIUS. The DGS-3630 Series also offers extensive VLAN support, including GVRP and 802.1Q VLAN to enhance security and performance. A robust set of QoS features help ensure that critical network services such as Voice over IP and video conferencing are given high priority through the network. The D-Link Safeguard Engine increases the switch’s reliability, serviceability, and availability by preventing malicious flooding traffic caused by worms or virus attacks.
	D-Link Green Technology
	The DGS-3630 Series features D-Link Green technology, which includes a power-saving mode, smart fan feature, reduced heat dissipation, and cable length detection. The power-saving feature automatically powers down ports that have no link or link partner, and ensures that LEDs are shut off when not needed. The smart fan3 feature allows for the built-in fans to automatically turn on only at a certain temperature, providing continuous, reliable, and eco-friendly operation of the switch.
	Versatile Management
	The DGS-3630 Series provides the D-Link Network Assistant Utility, an industry-standard CLI, and an intuitive web-based management interface that enables administrators to set up and remotely manage their networks. Support for SNMP allows centralized management of a large number of devices and out-of-band management is available via a dedicated console port. A mini-USB console port allows the DGS-3630 Series to be managed without any extra connectors, and a USB Type A port can be used to store logs, configuration, and firmware images. The DHCP auto-configuration and auto-image features can also be used to deploy multiple switches automatically, saving costs for mass deployment.
Põhiomadused
	Size
	• 19-inch, 1U rack-mount size
	Interfaces
	• 20 10/100/1000BASE-T ports
	• 4 Combo 10/100/1000BASE-T/SFP ports
	• 4 10 GbE SFP+ ports
	Console Port
	• RJ45 and Mini USB console ports for out-of-band CLI management
	Management Port
	• 10/100/1000BASE-T RJ-45 Ethernet for out-of-band IP management
	Alarm Port
	• 1 RJ-45 port
	USB Port
	• 1 USB 2.0 Type A port
	Performance
	• Switching Capacity: 128 Gbps
	• Packet Forwarding Rate: 95.24 Mpps
	• Packet Buffer: 4 MBytes
	• MAC Address Table: 68K entries2
	• IPv4 Routing Table: 16K entries
	• IPv6 Routing Table: 7K entries
	• IPv4 Forwarding Table: 32K entries
	• IPv6 Forwarding Table: 16K entries
	• Jumbo Frame Size: 12 KBytes
	Software Features
	Stackability
	• Physical Stacking
	  - Up to 80 Gbps stacking bandwidth
	  - Up to 9 switches in a stack
	  - Ring/chain topology support
	• Virtual Stacking/Clustering of up to 32 units
	  - Supports D-Link Single IP Management
	  - Up to 20 Gbps stacking bandwidth
	L2 Features
	• MAC Address Table : up to 68K entries2
	• Flow Control
	  - 802.3x Flow Control when using Full Duplex
	  - HOL Blocking Prevention
	• Spanning Tree Protocol
	  - 802.1D STP
	  - 802.1w RSTP
	  - 802.1s MSTP
	  - Root Guard
	  - Loop Guard
	• Jumbo Frame: up to 12 KBytes
	• 802.1AX Link Aggregation
	  - Max. 32 groups per device, 12 ports per group
	• ERPS (Ethernet Ring Protection Switching) version 2
	• Port Mirroring
	  - Supports One-to-One, Many-to-One,
	  - Supports Mirroring for Tx/Rx/Both
	  - Supports 4 mirroring groups
	• Flow Mirroring
	  - Supports Mirroring for Rx
	• VLAN Mirroring
	• RSPAN
	• L2 Protocol Tunneling
	VLAN
	• 802.1Q
	• 802.1v Protocol-based VLAN
	• Double VLAN (Q-in-Q)
	  - Port-based Q-in-Q
	  - Selective Q-in-Q
	• Port-based VLAN
	• MAC-based VLAN
	• Subnet-based VLAN
	• Private VLAN
	• VLAN Group
	  - Max. 4K VLAN groups
	  - Max. 4094 VIDs
	• Multicast VLAN (ISM VLAN for IPv4/IPv6)
	• Voice VLAN
	• Auto Surveillance VLAN
	• VLAN Trunking
	• GVRP: Up to 4K dynamic VLANs
	• Asymmetric VLAN
	L2 Multicast
	• MLD Snooping
	  - MLD v1/v2 Snooping
	  - Supports up to 4K MLD groups* (shared with IGMP Snooping)
	  - Host-based MLD Snooping Fast Leave
	  - Supports 128 static MLD groups (shared with IGMP)
	  - MLD Snooping Querier
	  - Per VLAN MLD Snooping
	  - MLD Proxy Reporting
	• IGMP Snooping
	  - IGMP v1/v2/v3
	  - Supports up to 8K IGMP groups* (shared with MLD Snooping)
	  - Supports 128 static IGMP groups (shared with MLD)
	  - Per VLAN IGMP Snooping
	  - IGMP Snooping Querier
	  - Host-based IGMP Snooping Fast Leave
	• PIM Snooping
	L3 Features
	• IPv4 ARP/IPv6 ND: support up to 32K/16K2
	  - 512 Static ARP
	• Gratuitous ARP
	• IP Interface
	  - Supports 256 interfaces
	• Loopback Interface
	• Proxy ARP
	  - Support local ARP proxy
	• IPv6 Tunneling
	  - Static
	  - ISATAP
	  - GRE
	  - 6to4
	• VRRP v2/v3
	• IP Helper
	L3 Routing
	• Supports 16K hardware routing entries shared by IPv4/IPv6
	  - 1 entry consumed by each IPv4 route
	  - 2 entries consumed by each IPv6 route
	• Supports up to 32K hardware L3 forwarding entries shared by IPv4/IPv62
	• Static Route
	  - Max. 512 IPv4 entries
	  - Max. 256 IPv6 entries
	• IPv4/IPv6 Default Route
	• PBR (Policy-based Route)
	• Null Route
	• Route Preference
	• Route Redistribution
	• Graceful Restart (GR) Helper
	• BFD (Bidirectional Forwarding Detection)
	  - IPv4/v6 Static Route
	  - RIP
	  - VRRP
	• RIPv1/v2/ng
	L3 Multicast
	• IGMP/MLD Filtering
	QoS (Quality of Service)
	• 802.1p
	• 8 queues per port
	• Queue Handling
	  - Strict Priority (SP)
	  - Weighted Round Robin (WRR)
	  - Strict + WRR
	  - Weighted Deficit Round Robin (WDRR)
	• Congestion Control
	• Weighted Random Early Detection (WRED)
	• 802.1Qbb Priority-based Flow Control (PFC) for 10 GbE port
	• Bandwidth Control
	  - Port-based (Ingress/Egress, min. granularity 8 Kb/s)
	  - Flow-based (Ingress/Egress, min. granularity 8 Kb/s)
	  - Per queue bandwidth control (min. granularity 8 Kb/s)
	• Policy Map
	  - Remark 802.1p priority
	  - Remark IP precedence/DSCP
	  - Time based QoS
	• CoS based on:
	• Switch Port
	  - Inner/ outer 802.1p Priority
	  - Inner/ outer VID
	  - MAC address
	  - Ether Type
	  - IP address
	  - ToS/IP Preference
	  - DSCP
	  - Protocol Type
	  - TCP/UDP port
	  - IPv6 Traffic Class
	  - IPv6 Flow Label
	• Three Color Marker
	  - trTCM
	  - srTCM
	ACL (Access Control List)
	• ACL based on:
	• 802.1p priority
	• VID
	• MAC address
	• EtherType
	• LLC
	• VLAN
	• IP address
	• IP preference/ToS
	• DSCP mask
	• Protocol type
	• TCP/UDP port number
	• IPv6 Traffic Class
	• IPv6 Flow Label
	• Max. ACL entries:
	• Ingress (hardware entries): 4K
	• Egress (hardware entries): 1K
	• VLAN Access Map Numbers: 3K
	• Time-based ACL
	Green
	• Energy Effeciency Ethernet (EEE)
	• Power Saving By Link Status
	• Power Saving By Cable Length
	• Power Saving By LED Shut-Off
	• Power Saving By Port Shut-Off
	• Power Saving By System Hibernation
	Security
	• Port Security
	  - Supports up to 12K MAC addresses per port/VLAN/system
	• Broadcast/Multicast/Unicast Storm Control
	• D-Link Safeguard Engine
	• DHCP Server Screening
	• Dynamic ARP Inspection
	• IP Source Guard
	• DHCP Snooping
	• IPv6 Snooping
	• Dynamic ARP Inspection (DAI)
	• DHCPv6 Guard
	• IPv6 Route Advertisement (RA) Guard
	• IPv6 ND Inspection
	• Duplicate Address Detection (DAD)
	• ARP Spoofing Prevention
	  - Max. 64 entries
	• L3 Control Packet Filtering
	• Unicast Reverse Path Forwarding (URPF)
	• Traffic Segmentation
	• SSL
	  - Supports TLS 1.0/1.1
	  - Supports IPv4/IPv6 access
	• SSH
	  - Supports SSH v2
	• BPDU Attack Prevention
	• DOS Attack Prevention
	• NetBIOS/NetBEUI filtering
	AAA
	• 802.1X Authentication
	  - Supports Port/Host-based access control
	  - Identity-driven Policy Assignment
	  - Dynamic VLAN Assignment
	  - Bandwidth Control Assignment
	  - ACL Assignment
	• Web-based Access Control (WAC)
	  - ACL Assignment
	  - Support IPv4/IPv6 access
	  - Support HTTPS
	• Compound Authentication
	• MAC-based Access Control (MAC)
	  - ACL Assignment
	• Guest VLAN
	• Microsoft® NAP
	  - Support 802.1X NAP
	  - Support DHCP NAP
	• Privilege Level for Management Access
	• RAIDUS and TACACS+ Authentication
	• Authentication Database Failover
	• RADIUS/TACACS+ Accounting
	OAM (Operations, Administration,and Maintenance)
	• Cable Diagnostics
	• 802.3ah Ethernet Link OAM
	• D-Link Unidirectional Link Detection (DULD)
	• Dying gasp
	• Y.1731 OAM
	• Optical Transceiver Digital Diagnostic Monitoring (DDM)
	Management
	• NTPv3/v4
	• Precision Time Protocol (PTPV2)
	• Web-based GUI
	• Support IPv4/IPv6 access
	• Support SSL (HTTPS)
	• Command Line Interface (CLI)
	• Telnet Server for IPv4/IPv6 access
	• Telnet Client for IPv4/IPv6
	• SNMP
	• Support v1/v2c/v3
	• SNMP Trap
	• TFTP Client for IPv4/IPv6
	• FTP Client for IPv4/IPv6
	• IPv4 SFTP Server
	• RCP
	• System Log for IPv4/IPv6 Syslog Server
	• SMTP
	• RMONv1
	• Supports 1,2,3,9 groups
	• RMONv2
	• Supports ProbeConfig group
	• Command Logging
	• LLDP/LLDP-MED
	• D-Link Discover Protocol (DDP)
	• DHCP Client option 12
	• DHCP Auto-configuration
	• DHCP Auto-image
	• DHCP Relay option 60/61/62/18/37/125
	• DHCP/DHCPv6 Local Relay
	• DHCP Server
	• Support IPv4/IPv6 address assignment
	• DHCPv6 Prefix Delegation (PD)
	• Multiple Images/ Multiple Configurations
	• DNS Relay for IPv4/IPv6
	• DNS Client for IPv4/IPv6
	• Debug Command
	• Password Recovery/ Encryption
	• Ping/ Traceroute for IPv4/IPv6
	• Microsoft® Network Load Balancing (NLB)
	• Switch Resource Management (SRM)
	• sFlow
	• D-Link License Management System (DLMS)
	Enhanced Image (EI) Features
	VLAN
	• Super VLAN
	L3 Routing
	• BGP
	• BGPv4/v4+
	• 4bytes AS
	• Text/MD5 for BGPv4
	• VRF-Lite
	• IPv4 Static Route
	• RIPv1/v2
	• OSPFv2
	• BGPv4
	• Bidirectional Forwarding Detection (BFD) for OSPF
	• OSPF
	• OSPF v2/v3
	• OSPF passive interface
	• Stub/NSSA area
	• OSPF equal cost route
	• Text/MD5 for OSPFv2
	L3 Multicast
	• IGMPv1/v2/v3
	• MLDv1/v2
	• IGMP/MLD Proxy
	• DVMRPv3
	• PIM-DM/SM/SSM/SDM
	• SSM Mapping for IPv4/IPv6
	• Multicast Source Discovery Protocol (MSDP)
	MPLS Image (MI) Features
	L3 Routing
	• IS-IS v4/v6
	MIB/IETF Standards
	• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure
	• RFC1213 MIBII
	• RFC1493, RFC4188 Bridge MIB
	• RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576 SNMP MIB
	• RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636 SNMPv2 MIB
	• RFC271, RFC1757, RFC2819 RMON MIB
	• RFC2021 RMONv2 MIB
	• RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635 Ether-like MIB
	• RFC2668 802.3 MAU MIB
	• RFC2674, RFC4363 802.1p MIB
	• Interface Group MIB
	• RFC4022 MIB for TCP
	• RFC4113 MIB for UDP
	• RFC2925 Ping & TRACEROUTE MIB
	• TFTP uploads and downloads (D-Link MIB)
	• Trap MIB (D-Link MIB)
	• RFC4293 IPv6 MIB
	• RFC4293 ICMPv6 MIB
	• Entity MIB
	• RIPv2 MIB
	• OSPF MIB
	• IPv4 Multicast Routing MIB
	• PIM MIB for IPv4
	• IP Forwarding Table MIB
	• RFC4293 IPv6 SNMP Mgmt Interface MIB
	• DDM MIB (D-Link MIB)
	• Private MIB
	• MIB for D-Link Zone Defense
	• DDP MIB
	• LLDP-MED MIB
	• RFC791 IP
	• RFC768 UDP
	• RFC793 TCP
	• RFC792 ICMPv4
	• RFC2463, RFC4443 ICMPv6
	• RFC826 ARP
	• RFC1338, RFC1519 CIDR
	• RFC2474, RFC3168, RFC3260 Definition of the DS Field in the IPv4 and IPv6 Headers
	• RFC1321, RFC2284, RFC2865, RFC2716, RFC1759, RFC3580, RFC3748 Extensible Authentication Protocol (EAP)
	• RFC2571 SNMP Framework
	• RFC2572 SNMP Message Processing and Dispatching
	• RFC2573 SNMP Applications
	• RFC2574 User-based Security Model for SNMPv3
	• RFC1981 Path MTU Discovery for IPv6
	• RFC2460 IPv6
	• RFC2461, RFC4861 Neighbor Discovery for IPv6
	• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration
	• RFC2767 Dual Stack Hosts using the ‘Bump-In-the-Stack’ Technology
	• RFC3513, RFC4291 IPv6 Addressing Architecture
	• RFC2893, RFC4213 IPv4/IPv6 dual stack function
	• RFC3484 Default Address Selection for Internet Protocol version 6
	Physical
	MTBF
	• 300,195.09 hours
	Acoustics
	• 52.7 dB(A)
	Heat Dissipation
	• 42.35 W (144.58 BTU/h)
	Power Input
	• 100 to 240 VAC 50/60 Hz
	Maximum Power Consumption
	• 42.4 W
	Standby Power Consumption
	• 28.1 W
	Dimensions
	• 441 x 259.8 x 44 mm (17.4 x 10.2 x 1.73 inches)
	Weight
	• 3.74 kg (8.36 lb)
	Ventilation
	• 2 x smart fans
	Operating Temperature
	• -5 to 50 °C (23 to 122 °F)
	Storage Temperature
	• -40 to 70 °C (-40 to 158 °F)
	Operating Humidity
	• 10% to 95% RH
	Storage Humidity
	• 5% to 95% RH
	Safety Certifications
	• cUL, CB, CE, CCC, BSMI
	EMI/EMC
	• CE, FCC Class A, C-Tick, VCCI, BSMI, CCC
Sertifikaadid
Sidustooted
DGS-3630-28TC/MI 20 10/100/1000BASE-T ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with MPLS Image
	Optional 10 Gbps SFP+ Transceivers
	DEM-431XT 10GBASE-SR Multi-mode, OM1:33M/OM2:82M/OM3:300M (w/o DDM)
	DEM-431XT-DD 10GBASE-SR Multi-mode, OM1:33M/OM2:82M/OM3:300M (with DDM)
	DEM-432XT 10GBASE-LR Single-mode, 10 km (w/o DDM)
	DEM-432XT-DD 10GBASE-LR Single-mode, 10 km (with DDM)
	DEM-433XT 10GBASE-ER Single-mode, 40 km (w/o DDM)
	DEM-433XT-DD 10GBASE-ER Single-mode, 40 km (with DDM)
	DEM-434XT 10GBASE-ZR Single-mode, 80 km (w/o DDM)
	DEM-436XT-BXD 10GBASE-LR Single-mode, 20 km (TX-1330/RX-1270 nm) (w/o DDM)
	DEM-436XT-BXU 10GBASE-LR Single-mode, 20 km (TX-1270/RX-1310 nm) (w/o DDM)
	Optional 1 Gbps SFP Transceivers
	DGS-712 1000BASE-T Copper SFP Transceiver
	DEM-210 100BASE-FX Single-mode, 15 km
	DEM-302S-LX 1000BASE-LX Single-mode, 2 km
	DEM-310GT 1000BASE-LX Single-mode, 10 km
	DEM-311GT 1000BASE-SX Multi-mode, 550 m
	DEM-312GT2 1000BASE-SX Multi-mode, 2 km
	DEM-314GT 1000BASE-LHX Single-mode, 50 km
	DEM-315GT 1000BASE-ZX Single-mode, 80 km
	DEM-220T 100BASE-BX-D Single-mode, 20 km (TX-1550/RX-1310 nm)
	DEM-220R 100BASE-BX-U Single-mode, 20 km (TX-1310/RX-1550 nm)
	DEM-302S-BXD 1000BASE-BX-D Single-mode, 2 km (TX-1550/RX-1310 nm)
	DEM-302S-BXU 1000BASE-BX-U Single-mode, 2 km (TX-1310/RX-1550 nm)
	DEM-330T 1000BASE-BX-D Single-mode, 10 km (TX-1550/RX-1310 nm)
	DEM-330R 1000BASE-BX-U Single-mode, 10 km (TX-1310/RX-1550 nm)
	DEM-331T 1000BASE-BX-D Single-mode, 40 km (TX-1550/RX-1310 nm)
	DEM-331R 1000BASE-BX-U Single-mode, 40 km (TX-1310/RX-1550 nm)
	Optional 10 Gbps SFP+ Direct Attach Cables
	DEM-CB100S 10 GbE SFP+ 1 m Direct Attach Cable
	DEM-CB300S 10 GbE SFP+ 3 m Direct Attach Cable
	DEM-CB700S 10 GbE SFP+ 7 m Direct Attach Cable
	Optional Redundant Power Supplies
	DPS-500A   AC Redundant Power Supply
	DPS-500DC  DC Redundant Power Supply
