Kiirotsing
Toote omadused:
Unmanaged Switch with 24 10/100Base-TX ports
Põhiomadused:
Features
Interfaces
• 24 10/100Base-TX ports
Port Standard & Functions
• IEEE 802.3 10Base-T Ethernet
• IEEE 802.3u 100Base-TX Fast Ethernet
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x flow control
• IEEE 802.3az EEE function
Diagnostic LEDs
• Power
• Link/Activity (Per port)
Network Cables for 10GBase-T
• 10BASE-T:
  UTP CAT 3/4/5/5e (100 m max.)
  EIA/TIA-586 100-ohm STP (100 m max.)
• 100BASE-TX:
  UTP CAT 5/5e (100 m max.)
  EIA/TIA-568 100-ohm STP (100 m max.)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all ports
Data Transfer Rates
• Fast Ethernet:
  100 Mbps Half-Duplex
  200 Mbps Full-Duplex
• Ethernet:
  10 Mbps Half-Duplex
  20 Mbps Full-Duplex
Switching Capacity
• 4.8 Gbps
Maximum Packet Forwarding Rate
• 3.57 Mpps
Transmission Method
• Store-and-forward
MAC Address Table
• 8K entries per device
MAC Address Learning
• Automatic update
Packet Buffer
• 256 Kbytes
Jumbo Frame
• 2 Kbytes
Physical Parameters
Power Input
• 100 to 240 V AC
Maximum Power Consumption
• 2.8 W
Standby Power Consumption
• 1.17 W
Heat Dissipation
• 9.5536 BTU/h
MTBF
• 810,880 hours
Weight
• 1.14 kg
Dimensions
• 282 x 150 x 44 mm
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certifications
• CE
• FCC
• ICES-003
• BSMI
• RCM
• CCC
• VCCI
• cUL
• CB
• LVD
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
