DMS-1100-10TP
Switch with 8 2.5GBASE-T PoE ports and 2 10G SFP+ ports
Kust osta
Kirjeldus
The D-Link DMS-1100 Series 2.5 Gigabit Ethernet Smart Managed Switches are a cost-effective 2.5 Gigabit switch series capable of servicing a range of network needs in any type of business.
Featuring eight 2.5 Gigabit access ports and two 10 Gigabit SFP+ uplink ports, this series is ideal for deploying multiple high-performance 802.11ac Wave 2 access points using 2.5 Gigabit
connections, while providing a 10 Gigabit wire-speed uplink for optimal bandwidth when accessing the larger local area network.
Seamless Integration and Future Proof
The DMS-1100 Series supports IEEE 802.3bz and is fully backwards compatible with 802.3ab Gigabit Ethernet to deliver 2.5 Gigabit speed over conventional, widespread available Cat 5e cables over a distance of up to 100 meters. Driven by the increasing popularity of 802.11ac Wave 2 access points and the emerging trend of 2.5 Gigabit LAN connections, 2.5 Gigabit technology will soon replace Gigabit as the standard for Ethernet connectivity. With backwards compatibility for older standards, the DMS-1100 Series can be flawlessly integrated into existing Gigabit Ethernet network infrastructures while simultaneously making your network future-proof for the next generation of 2.5 Gigabit connectivity.
Complete Layer 2 and Troubleshooting Features
The DMS-1100 Series comes with a complete lineup of L2 features, including port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). The DMS-1100 Series also features loopback detection and cable diagnostics to help network administrators identify and solve network problems quickly and easily. Loopback detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable diagnostics helps network administrators quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
Versatile Management
The DMS-1100 Series comes with the D-Link Network Assistant (DNA) utility that simplifies the configuration of devices that support the D-Link Discovery Protocol. The D-Link Network Assistant utility easily allows customers to discover multiple D-Link Smart Managed Switches within the same L2 network segment and displays them on screen for instant access. With this utility, users do not need to change the IP address of their PC. This utility further allows for simultaneous configuration and basic setup of all discovered devices, including password changes and firmware upgrades. The DMS-1100 Series also supports D-View. D-View is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
Power over Ethernet Support
The Power over Ethernet-ready DMS-1100-10TP features a total power budget of 240 W, capable of supplying up to 30 W of power per port to connected PoE-enabled devices. Power over Ethernet simplifies deployment of surveillance devices and access point infrastructures by reducing cable clutter, and eliminating the need for dedicated power supplies to allow PoE devices to be installed in remote locations.
Põhiomadused
Features
Interfaces
• 8 100/1000/2.5GBASE-T PoE ports
• 2 SFP+ ports
Port Standard & Functions
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3z 1000Base-X
• IEEE 802.3bz 2.5GBase-T
• IEEE 802.3ae 10G over fiber
• IEEE 802.3az
• IEEE 802.3af
• IEEE 802.3at
Diagnostic LEDs
• Power
• Link/Activity (Per port)
• FAN error
• PoE Status
Network Cables for 2.5GBase-T
• Cat 5e (100 m max)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all twisted-pair ports
Switching Capacity
• 80 Gbps
Maximum Packet Forwarding Rate
• 59.52 Mpps
Transmission Method
• Store-and-forward
MAC Address Table
• 16K entries per device
Packet Buffer
• 1.5 Mbytes
Jumbo Frame
• 9 Kbytes
PoE Budget
• 240 W
Software
L2 Features
• Flow control
  • 802.3x Flow control
  • HOL Blocking Prevention
• IGMP Snooping
  • IGMP v1/v2/v3 Snooping
  • Supports 192 groups (shared with MLD Snooping)
  • IGMP Snooping Querier
  • IGMP Snooping Fast Leave
• MLD Snooping
  • MLD snooping v1/v2
  • Supports 192 groups (shared with IGMP Snooping)
  • MLD Snooping Querier
   • MLD Snooping Fast Leave
• 802.3ad Link Aggregation:
  • Support 8 groups per device and 8 ports per group
• Loopback Detection V4.07
• LLDP/LLDP-MED
• Port Mirroring
  • One-to-One
  • Many-to-One
  • Mirror based on Tx
  • Mirror based on Rx
• Statistics
  • Tx Ok
  • Tx Error
  • Rx Ok
  • Rx Error
• Spanning Tree Protocol
  • 802.1D STP
  • 802.1w RSTP
• Ethernet Ring Protection Switching
  • G.8032 ERPS single ring
  • 16 max nodes per ring
VLAN
• 802.1Q tagged VLAN
• Port-based VLAN
• Auto Surveillance VLAN 2.0*
• Voice VLAN
• Asymmetric VLAN
• VLAN Group
  • Supports 4094 static VLAN groups
  • Max. 4094 VIDs
Quality of Service (QoS)
• 802.1p Quality of Service
  • 8 queues per port
  • Strict Priority Queue (SPQ)
  • Weighted Round Robin (WRR)
  • Port-based bandwidth control (rate limiting)
• Ingress bandwidth control
• Egress bandwidth control
Security
• D-Link Safeguard Engine
• Traffic segmentation
• Broadcast/Multicast/Unknown Unicast Storm Control
• DoS attack prevention
• SSLv3/TLS 1.2
  • IPv4 support
  • IPv6 support
OAM
• Cable diagnostics
• Factory reset
AAA
• Trusted Host
Management
• Web-based GUI (supports IPv4/IPv6)
• Smart Wizard
• Client-based D-Link Network Assistant (DNA)
• SNTP
• SNMP
  • Supports v1/v2c
• SNMP trap
• System log
• DHCP/BootP client
• TFTP client
• D-Link Discovery Protocol (DDP)
• Dual images
• Dual configurations
• Ping
Green Technology
• Power saving features
  • LED shutoff
  • Link status
  • Port shutoff
  • System hibernation
  • Time-based PoE
MIB/RFC Standards
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1213 MIB II
• RFC1493 Bridage MIB
• RFC1907 SNMPv2 MIB
• RFC4363 IEEE 802.1p MIB
• ZoneDefense MIB
• Private MIB
• PoE MIB
Physical Parameters
Power Input
• 100 to 240 V AC
Maximum Power Consumption
• 293.4 W (PoE on)
• 38.1 W (PoE off)
Standby Power Consumption
• 27.3 W
Heat Dissipation
• 1000.91 BTU/h
MTBF
• 676,329 hours
Weight
• 3.43 kg
Dimensions
• 440 x 250 x 44 mm
Temperature
• Operating: -5 to 50 °C
• Storage: -40 to 70 °C
Humidity
• Operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
EMI
• CE
• FCC
• C-Tick
• VCCI
• BSMI
• CCC
Safety
• cUL
• CB
• CE
• CCC
• BSMI
* This feature will be supported in a future firmware release.
Füüsilised parameetrid
Sertifikaadid
Sidustooted
DMS-1100-10TP  Switch with 8 2.5GBASE-T PoE ports and 2 10G SFP+ ports
Pildid
DMS-1100-10TP/A
Eestvaade
Tagantvaade
Paremvaade
Failid
Vaadake samuti
