DES-3526
Hallatav 2 taseme kommutaator 24 x 10/100Base-TX pordiga + 2 kombo-porti 1000Base-T/Mini GBIC (SFP)
Kust osta
Kirjeldus
  • 24-Port 10/100BASE-TX per switch
  • 2 combo 1000BASE-T/SFP Gigabit uplinks per switch
  • Virtual stacking of up to 32 units per stack
  • Up to 8.8Gbps Switching Capacity
  • Complete network access management solution
  • Multi-layer (L2, L3, L4) Quality of Service
  • Advanced Access Control Lists (ACL), enhanced TACACS+ and RADIUS authentication*
  • 802.3ad LACP Link Aggregation port trunks
  • IGMP snooping for multimedia applications
  • CLI, Web-based and SNMP management, RMON monitoring
  • Optional redundant power support
  • 8000 MAC Address Table
D-Link’s DES-3526 is a high-performance, managed, stackable Layer 2 switch that provides an ideal solution for workgroups and departments. The D-Link Single IP Management (SIM) allows to cluster up a virtual stack of up to 32 DES-3526 and/or DES-3550 dispersed switches with fewer distance limitation through a single IP address.
The clustering environment spans buildings, making it perfect for business that requires multiple building deployment. The (24) 10/100Mbps Fast Ethernet ports allow desktops to access network resources through flexible 2 Gig uplinks. The entire virtual stack can be managed via a single IP address for simplified network administration.
High-Performance, High Availability L2 Switching
Utilizing an 8.8Gbps switch capacity and support for 8,000 MAC addresses, the DES-3526 Stackable Layer 2 Switch is a wire-speed, high performance switch ideal for workgroups or departments. The DES-3526 supports port trunking with up to 6 trunk groups with 2 to 8 ports in each group per stack. Port trunking enables business users to increase availability and aggregated bandwidth between servers and/or other switches, optimizing the transport of business critical data. The DES-3526 can utilize either the 10/100Mbps or the 1 Gbps port to interconnect up to 32 units within a virtual stack.
Investment Protection
By widely supporting IEEE approved specifications, the DES-3526 Stackable Layer 2 Switch leverages your existing investment in a multi-vendor environment, while maximizing compatibility of mission critical features such as, Spanning Tree (802.1d), QoS (802.1p/DiffServ/TCP &UDP port number), VLANs (802.1Q), and network management (SNMP/RMON/BOOTP/Telnet/Web).
The DES-3526’s robust support of standards-based network management protocols (SNMP/RMON/BOOTP/ Telnet/Web/TFTP) and port mirroring enables the DES-3526 to be easily integrated into many third-party network management packages.
Advanced Enterprise Features
The DES-3526 Stackable Layer 2 Switch brings advanced enterprise functions to a more affordable level while supporting advanced features: D-Link Single IP Mangement, Dual Images, L2/L3/L4 (QoS), 802.1x (Port-based Authentication), 802.1x (MAC-based Authentication)IGMP snooping, 802.1w (Rapid Spanning Tree), 802.1s (Multiple Spanning Tree group), 802.3ad (Link Aggregation), and 802.1q (VLANs). L2/L3/L4 (ACLs) can be configured based on: Protocol type, 802.1p, DSCP, MAC Address, IP Address, and/or TCP/UPD Port Number. These features facilitate the deployment of enterprise applications such as: VOIP, streaming media, and multicast content delivery (IP video conferencing and software deployment).
* RADIUS support available in future firmware upgrade
Põhiomadused
   Portide arv
  • 24 x 10/100BASE-TX porti, 2 kombo porti 1000BASE-T/MiniGBIC (SFP)
    Standardid ja funktsioonid
  • IEEE 802.3 10BASE-T/802.3u 100BASE-TX
  • IEEE 802.3ab 1000BASE-T/802.3z 1000BASE-SX/LX
  • ANSI/IEEE 802.3 NWay
  • IEEE 802.3x voojuhtimine
  • Kaabli polaarsuse automaatne tuvastamine MDI/MDIX
  • Portide peegeldamine
    SFP toetus
  • IEEE 802.3z 1000BASE-LX (DEM-310GT transiiver)
  • IEEE 802.3z 1000BASE-SX (DEM-311GT transiiver)
  • IEEE 802.3z 1000BASE-LH (DEM-314GT transiiver)
  • IEEE 802.3z 1000BASE-ZX (DEM-315GT transiiver)
  • IEEE 802.3z 1000BASE-LX (DEM-330T transiiver)
  • IEEE 802.3z 1000BASE-LX (DEM-330R transiiver)
  • IEEE 802.3z 1000BASE-LX (DEM-331T transiiver)
  • IEEE 802.3z 1000BASE-LX (DEM-331R transiiver)
    Tarkvara
    VLAN
  • IEEE 802.1Q Tagged VLAN
  • VLAN portide baasil
  • GARP/GVRP
  • Maksimaalne VLAN arv: 255 VLAN (staatilised ja dünaamilised summaarselt)
    Prioriteedi järjekorrad (CoS)
  • Standart: IEEE 802.1p
  • Järjekordade arv: 4
    Liikluse klassifitseerimine (CoS)
  • TOS
  • Diffserv (DSCP)
  • Portide baasil
  • MAC-аadressite baasil
  • IP-aadressi baasil
  • TCP/UDP pordi numbri baasil
    Järjekordade juhtimine
  • Strict priority ja Weighted fair queuing
    Ligipääsu juhtimine
  • Port security funktsioon (maksimaalselt 20 МАС-aadresi)
  • Ligipääsu juhtimine 802.1x portide baasil
  • Ligipääsu juhtimine 802.1x MAC-aadressite baasil
  • SSH v.1, v.2
  • SSL
  • Liikluse segmenteerimine (koos või ilma VLAN tag)
  • IP-MAC-Port Binding: 512 kirjet
    Access Control List
    Mitmetasemelised ACL:
  • Porti number
  • TOS
  • Diffserv (DSCP)
  • MAC-аadress
  • IP -аadress
  • Paketi protokolli tüüp
  • TCP/UDP pordi number
  • Paketi sisu baasil, kasutajaga määratav
  • ACL iga pordi jaoks
    Spanning Tree protokoll
  • 802.1D Spanning Tree ühilduvus
  • 802.1w Rapid Spanning Tree
  • 802.1s Multiple Spanning Tree
  • BPDU filtreerimine iga pordi jaoks
  • STP Loopback Detection toetus
    IP grupiline saatmine
  • IGMP v.3 Snooping (maksimaalselt 128 gruppi)
  • VLAN tuvastamine grupilise saatmise jaoks
  • IGMP Fast Leave
  • IP-aadressite grupilise saatmise diapasooni kasutajaga piiramine iga pordi jaoks
    Portide agregeerimine
  • Maksimaalne portide arv trank grupis: 8
  • Marsimaalne trank gruppide arv seadmele: 6
  • Töörežiim: koormuse jaotus
  • Link Aggregation (LACP) staatilised ja dünaamilised režiimid, 802.3ad ühilduvad
    Tootlikkuse suurendamise funktsioonid
  • Ribalaiuse juhtimine (Fast Ethernet portide jaoks – 1 Мbit/с
  • s samm, Gigabit Ethernet portide jaoks – 8 Мbit/s samm)
    Tootlikkus
    Kommutaatori tootlikkus
  • 8.8 Gbit/s
    Paketide andmeedastuskiirus
  • 6.6 mln pakette sekundis
    Kommutatsiooni meetod
  • Store-and-forward
    MAC-аadressite tabeli suurus
  • 8 K kirjet seadmele
    MAC-аadressite uurimine
  • Dünaamiline: automaatne uuendamine
  • Staatiline: kasutajaga määratud
    Buffemälu
  • 16 Mb seadmele
    Häälestamine ja juhtimine
    Juhtimine
  • Single IP Management v.1
  • SNMP v.1, v.2c, v.3
  • Web-liides
  • Liikluse monitooring Web GUI liidese kaudu
  • MAC-aadressite vaatamine Web-liidese kaudu
  • CLI (command line interface)
  • RMON monitooring
  • Telnet server (kuni 8 sessiooni)
  • TACACS+ autentimine
  • RADIUS autentimine
  • SYSLOG
  • Kahe tarkvara koopiate toetus (Dual Images)
  • Back-Door funktsioon
  • Portide kirjeldus
  • RFC 2030 SNTP (Simple Network Time Protocol)
  • CIT ja NMS liidesed (SNMP protokolli kaudu)
  • VT-100 CLI (command line interface)
  • DHCP/Bootp Relay ja DHCP Relay Agent Option 82 toetus
  • Telnet, Web, SNMP kaugjuhtimise sisse-/väljalülitamine
  • Portide seisundi vaatamine Web-liidese kaudu
  • Kommutaatori konfiguratsiooni lisamine, kustutamine, muutmine
  • Mitmete portide samaaegne seadistamine
  • NVRAM, TFTP
  • RFC 3164 Syslog
    MIB
  • 802.1Q Q-BRIDGE-MIB (RFC 2674)
  • 802.1p P-BRIDGE-MIB (RFC 2674)
  • MIB-II (RFC 1213)
  • Bridge MIB (RFC 1493)
  • RMON MIB (RFC 1757)
  • IGMP MIB (RFC 2833)
  • IF MIB (RFC 2233)
  • Ethernet-like MIB (RFC 1643)
  • PING-MIB and TRACEROUTE-MIB (RFC 2925)
  • ICMP Ping by MIB
  • Rate limiting by MIB
  • Save configuration by MIB
  • 802.1w setting and read by MIB
  • Port interface MIB-II trap (RFC 1215)
  • D-Link enterprise MIB
    RMON grupid
  • 1, 2, 3, 9 (Alarm, Statistics, History, Event)
    IP-аadressi saamine
  • DHCP klient, Bootp klient
    Tarkvara uuendamine
  • TFTP
    Konsoolport
  • DB-9 RS-232 DCE
Füüsilised parameetrid
Indikaatorid
Seadmele:
  • Power
  • Console
  • RPS
    Pordile:
  • 10/100 Mbps
  • GE
    Toide
  • 100 ~ 240 V, 50/60 Hz
  • Sisene universaalne toiteallikas
    Varutoiteallikas
  • Pesa varutoiteallika ühendamiseks
    Tarbitav võimsus
  • 23 W (max)
    Jahutus
  • 40 x 40 mm DC ventillaator x 1
    Mõõdud
  • 441 x 207 x 44 mm (ainult seade)
  • 19", kõrgus 1 U
    Kaal
  • 2.56 kg (ainult seade)
    Töötemperatuur
  • 0o kuni 40o
    Säilitamistemperatuur
  • -40o kuni 70o
    Niiskus
  • 5% kuni 95% ilma kondensatsioonita
    EMI
  • FCC Class A
  • CE Class A
  • C-Tick
    Turvalisus
  • CSA International
    MTBF
  • 53818 tundi
Sertifikaadid
Sidustooted
DES-3526 Hallatav 2 taseme kommutaator 24 x 10/100Base-TX pordiga + 2 kombo-porti 1000Base-T/Mini GBIC (SFP)
Lisa mini GBIC SFP transiiverid
DEM-310GT SFP transiiver 1000BASE-LX, SMF, maksimaalne vahemaa kuni 10 km, 3.3 V
DEM-311GT SFP transiiver 1000BASE-SX, MMF, maksimaalne vahemaa kuni 550 m, 3.3 V
DEM-312GT2 SFP transiiver 1000BASE-SX, MMF, maksimaalne vahemaa kuni 2 km, 3.3 V
DEM-314GT SFP transiiver 1000BASE-LH, SMF, maksimaalne vahemaa kuni 50 km, 3.3 V
DEM-315GT SFP transiiver 1000BASE-ZX, SMF, maksimaalne vahemaa kuni 80 km, 3.3 V
DEM-330T SFP transiiver 1000BASE-LX, SMF, maksimaalne vahemaa kuni 10 km, 3.3 V, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-330R SFP transiiver 1000BASE-LX, SMF, maksimaalne vahemaa kuni 10 km, 3.3 V, WDM (Tx: 1310 nm, Rx:1550 nm)
DEM-331T SFP transiiver 1000BASE-LX, SMF, maksimaalne vahemaa kuni 40 km, 3.3 V, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-331R SFP transiiver 1000BASE-LX, SMF, maksimaalne vahemaa kuni 40 km, 3.3 V, WDM (Tx: 1310 nm, Rx:1550 nm)
DGS-712 SFP transiiver 1000BASE-T, maksimaalne vahemaa kuni 100 m 3.3 V
Varutoiteallikas
DPS-200 - varutoiteallikas 60 W
Pildid
DES-3526/RFB без пластиковой накладки на переднюю панель
Eestvaade
DES-3526/RFB с металлической передней панелью
Eestvaade
DES-3526/RFB с пластиковой накладкой на переднюю панель
Eestvaade
DES-3526/RFB с пластиковой накладкой на переднюю панель, доработанной под установку SFP-трансивера
Eestvaade
DES-3526
Eestvaade
Tagantvaade
Failid
Vaadake samuti
