DGS-3100-24PEOL EOS
Kirjeldus
The DGS-3100 series switches are managed Layer 2 Gigabit stackable switches designed T as feature-rich, low-cost devices in the entry-level network management category. These switches provide wide-ranging port densities and up to 20Gbps physical stacking. Outstanding features include scalable expansion, SFP fiber links, comprehensive network security, granular bandwidth control and extensive network management. Small to medium businesses (SMBs) looking for a flexible, advanced and affordable solution can deploy these switches to set up Gigabit connections to their desktops or build up a company-wide network backbone.
Physical Stacking. Each of the DGS-3100 series switches comes with 2 dedicated HDMI stacking ports, each providing 5Gbps stacking bandwidth (up to 20Gbps for the overall system in full-duplex mode, bi-directional). Up to 6 units, 288 10/100/1000Mbps ports can be stacked up in a linear or fault-tolerant Ring topology. A stack can consist of 10/100/1000Mbps switches, 10/100/1000Mbps PoE switches, or a combination of both types, with up to 96 SFP fiber links. Units can be gradually added to the stack to accommodate growth, while expansion beyond a single stack is possible using Gigabit port trunks between stacks, or from stack to network backbone and server paths.
Security & Availability. The DGS-3100 stack includes many security features including Access Control List (ACL), 802.1X Port-Based/MAC-Based Access Control and 802.1X Guest VLAN to make network access available to authorized users. To prevent malicious attacks and virus/worm affection from overwhelming the switch with unnecessary workload, the DGS-3100 stack provides the D-Link Safeguard Engine function to increase the switch's reliability and availability.
Resilience/Performance Enhancement. To enhance network resilience, the DGS-3100 stack provides Spanning Tree protocols, including 802.1D, 802.1w and 802.1s for redundant bridge paths. 802.3ad Link Aggregation provides the aggregated bandwidth between switches or server. For Quality of Service (QoS), it supports 802.1p Priority Queues and packet classification based on TOS, DSCP, MAC, IP, VLAN ID and L4 protocol types, enabling Internet voice, video and streaming media applications to run smoothly. Traffic Monitoring/Bandwidth Control. Network administrators can define throughput levels for each port to manage bandwidth. The bandwidth limiting feature provides fine granularity with the ability to define limits down to 64Kbps segments. Broadcast storm control can reduce the level of damage that a virus attack can do to the network. The switch provides IGMP snooping 2 and MLD snooping to control multicast transmission, and port mirroring to facilitate diagnostics.
Management. The DGS-3100 stack supports standard-based management protocols such as SNMP, RMON, Telnet, Web GUI and SSH/SSL security authentication. With DHCP auto-configuration, the administrator can pre-set configurations and save them in a TFTP server, and individual switches can boot their IP from the server and load in the pre-set configurations.
Põhiomadused
Liidesed
Füüsiline stack
- ringtopoloogia jaoks: kuni 20 Gbit/s
Power over Ethernet
Tootlikkus
Teise taseme funktsioonid
- HOL blokeerimise ennetamine
- Kuni 256 gruppi toetus
- IGMP Snooping Fast Leave
- 128 gruppi toetus
- 802.1w RSTP
- 802.1s MSTP
- Many-to-One
VLAN
- 256 dünaamilist VLAN gruppi
QoS (Teenusekvaliteet)
- Weighted Round Robin (WRR)
- Strict + WRR
- VLAN ID
- Järjekordade prioriteetsus 802.1р
- МАС-aadress
- Ether type
- IPv4-aadress
- DSCP
- Protokolli tüüp
- TCP/UDP pordi number
ACL
- VLAN ID
- Ether type
- МАС-aadress
- IPv4-aadress
- DSCP
- Protokolli tüüp
Turvalisus
AAA (autentimine, autoriseerimine, kasutajatunnuste haldamine)
Juhtimine
Standardid MIB/IETF
* Funktsioon muutub saadavaks tarkvara järgmistes versioonides.
Sertifikaadid
Sidustooted
DGS-3100-24P Hallatav L2 stack kommutaator, 20 PoE 10/100/1000Base-T porti, 4 kombo porti 1000Base-T/SFP
Lisa SFP transiiverid
DEM-310GT SFP transiiver 1000BASE-LX, SMF, max vahemaa kuni 10 km, 3.3 V
DEM-311GT SFP transiiver 1000BASE-SX, MMF, max vahemaa kuni 550 m, 3.3 V
DEM-312GT2 SFP transiiver 1000BASE-SX, MMF, max vahemaa kuni 2 km, 3.3 V
DEM-314GT SFP transiiver 1000BASE-LH, SMF, max vahemaa kuni 50 km, 3.3 V
DEM-315GT SFP transiiver 1000BASE-ZX, SMF, max vahemaa kuni 80 km, 3.3 V
DEM-210 SFP transiiver 100BASE-FX, SMF, max vahemaa kuni 15 km, 3.3 V
DEM-211 SFP transiiver 100BASE-FX, MMF, max vahemaa kuni 2 km, 3.3 V
DEM-220T SFP transiiver 100BASE-BX, max vahemaa kuni 20 km
DEM-220R SFP transiiver 100BASE-BX, max vahemaa kuni 20 km
Lisa WDM transiiverid
DEM-330T SFP transiiver 1000BASE-LX, SMF, max vahemaa kuni 10 km, 3.3 V,WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-330R SFP transiiver 1000BASE-LX,SMF, max vahemaa kuni 10 km, 3.3 V,WDM (Tx: 1310 nm, Rx:1550 nm)
DEM-331T SFP transiiver 1000BASE-LX, SMF, max vahemaa kuni 40 km, 3.3 V,WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-331R SFP transiiver 1000BASE-LX, SMF, max vahemaa kuni 40 km, 3.3 V, WDM (Tx: 1310 nm, Rx:1550 nm)
Varutoiteallikas
DPS-600 Varutoiteallikas, 500 W
DPS-800 Šassii varutoiteploki jaoks 2 pesaga
DPS-900 Šassii varutoiteploki jaoks 8 pesaga
Lisa juhtimistarkvara
DV-600S ja DV-600P Võrgu juhtimistarkvara D-View 6.0 SNMP
