DKVM-CU
1.8 m KVM cable with VGA and USB
Kust osta
Kirjeldus
The DKVM-CU 1.8 m KVM cable allows you to connect your PC to the D-Link DKVM-4U/C KVM switch. The cable has one USB Type-A connector for connecting to the USB Type-A port on your PC and two 15-pin HDB connectors for connecting to the VGA port on your PC and on the KVM switch.
The DKVM-CU combines several cables in one assembly, thus allowing you to save space on your table.
Põhiomadused
Length
• 1.8 m
Keyboard/Mouse
• One USB Type-A connector
Video
• Two 15-pin HDB connectors (VGA)
Advanced features
• Several cables in one assembly
NOTE! The DKVM-CU KVM cable of hardware version B is compatible only with the DKVM-4U KVM switch of hardware version C.
Füüsilised parameetrid
Sertifikaadid
Sidustooted
DKVM-CU  1.8 m KVM cable with VGA and USB
Pildid
DKVM-CU/Bx
Eestvaade
Failid
Vaadake samuti
