DCM-202/RU/C
DOCSIS/EuroDOCSIS 2.0 Cable Modem with 1 10/100BASE-TX Fast Ethernet Port, USB Port and CaTV Connector
Kirjeldus
With support for the increased bandwidth DCM-202 TurboDoxTM Modem increases the download speed up to 20 times, allowing unlimited usage of popular Internet applications, such as file sharing, viewing and listening to audio and video streaming, Internet TV and viewing Web-pages*.
Compliant with DOCSIS standards
DCM-202 DOCSIS/EuroDOCSIS 2.0 Cable Modem increases the efficiency of broadband connection, avoiding network overload, which greatly increases the connection speed. With the DCM-202 users derive maximum benefit from a broadband connection invested in funds due to higher download speeds and higher productivity. DCM-202 is DOCSIS 2.0 certified by CableLabs and provides compatibility with all cable providers which support DOCSIS. DCM-202 is backward-compatible with DOCSIS 1.1/1.0.
Ethernet and USB connection
DCM-202 offers a choice of connecting to a computer via Ethernet or USB. Modem Installation is effortless, the device is compatible with Windows XP/Vista/7, Mac OSX, Unix and other popular operating systems (USB connection only supports Windows XP, Vista and 7). Connect to a certified cable Internet service provider with confidence using the DCM-202 and take advantage of new broadband connection to the Internet.
* Speed may vary depending on the cable Internet service provider. For more information, please contact your provider.
Põhiomadused
Device Interfaces
• Compatible with DOCSIS/EuroDOCSIS 2.0
• Compatible with DOCSIS/EuroDOCSIS 1.1
• Compatible with DOCSIS/EuroDOCSIS 1.0
• IEEE 802.3/802.3u 10/100BASE-TX Ethernet
• USB 1.1 Type B
Interface
• 10/100BASE-TX Ethernet port (Auto MDI/MDIX)
• USB port
• Coaxial CATV connector, "female" type
Data transfer rate: Downstream
• Demodulation: 64/256QAM
• Max. speed: 38 Mbps (64QAM).43 Mbps (256QAM)
• Frequency range: 91 to 857 MHz ± 30 kHz (accuracy)
• Bandwidth: 6 MHz
• Signal level: -15 dBmV to 15 dBmV (gain automatically controlled by modem)
Data Transfer Rate: Upstream
• Modulation: 64/256QAM
• TDMA: QPSK, 8QAM, 16QAM, 32QAM, 64QAM, 128QAM
• Max. speed: 320, 640, 1280, 2560 5120 Kbps (16QAM)
• Frequency range: 5 to 42 MHz (including the boundary values)
• Bandwidth: 0.2, 0.4, 0.8, 1.6, 3.2 MHz
• TDMA: 200, 400, 800, 1600, 3200 and 6400 kHz
• S-CDMa: 1600, 3200 and 6400 KHz Power
Power
• Power Input: 5 V, 1.2 A via power adapter
• Power Consumption: 5 W (standby mode), 6 W (operating mode)
Supported OS
• Windows XP/Vista/7 (Ethernet and USB)
• Mac OS (Ethernet only)
• Unix/Linux (Ethernet only)
Supported Protocols
• Protocol: ICMP/SNMP V1, V2c, V3
• MIB: MIB II/MCNS MIB
Diagnostic Lights
• Link/Activity
• Online Status
• Upstream
• Downstream
• Power
Physical Parameters
Dimensions
• 109 х 90 х 32 mm
Weight
• 162 g
Operating Temperature
• 0° to 40°С
Storage Temperature
• -20° to 60°С
Humidity
• Operating: 10% to 90% (non-condensing)
Certificates
• FCC Part 15 Class B
• CE
• UL
• CableLabsTM comliant
Sertifikaadid
Sidustooted
DCM-202/RU/C    DOCSIS/EuroDOCSIS 2.0 Cable Modem with 1 10/100BASE-TX Fast Ethernet Port, USB Port and CaTV Connector
Pildid
DCM-202/RU/C
Eestvaade
Failid
Vaadake samuti
