Kirjeldus
The DFM-562IS is a software modem card.  It plugs into a PCI expansion bus slot of a desktop PC.  It supports voice, fax and data transmission/reception.  It's a high-performance CONEXANT-based modem card,
and can be used to connect to the Internet, and for fax and voice communication.
