DSN-2100-10EOL EOS
xStack 8-kettaavaga kettamassiiv iSCSI liidesega
Kust osta
Kirjeldus
The  D-Link  DSN-2100  xStack  Storage  Area  Network (SAN) Array  is designed  to provide a smaller, more value oriented solution for entry-level and SMB customers. The heart  of  the  DSN-2100  is  based  on  the  same  powerful System-on-a-Chip  (SoC)  design  found  in  larger  arrays such as the DSN-3000 series of products, but housed in a smaller chassis. Utilizing a 10Gbit  iSCSI SoC solution that can  handle  over  80,000  I/Os  per  second  and  capable  of supporting 8TBs of raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced), the  DSN-2100  SAN  Array  can  easily  be  implemented  as nearline storage or as a supplement to your primary backup and  recovery  device.  This  evolutionary  advancement in  performance  is  a  testament  to  the  tightly  integrated xStack Storage architecture and is a sharp contrast to the discrete implementation of competing products.
iSCSI for IP Networks
SAN  has  been  traditionally  reserved  for  Fibre  Channel networks  until  the  recent  introduction  of  iSCSI  that extends  this  powerful  yet  simple  centralized  backend storage  system  to  IP  networks.  By  utilizing  existing Ethernet  technology,  the  cost  associated  with  separate host bus adapters and  the per-Gigabyte cost  for storage  is signifcantly reduced. iSCSI SANs can leverage the Ethernet infrastructure and standards which are quite familiar to your IT staff.
Four 1GbE Interfaces
The DSN-2000 Series SAN Array implements four 1GbE ports and  supports  IEEE  802.3ad  Link Aggregation Groups  (LAG) for full offoad capability so that all four ports can be grouped together,  totaling  up  to  425MB/s  bandwidth,  for  increased throughput and redundancy.
System-on-a-Chip (SoC) Implementation
By utilizing a SoC design, the DSN-2000 Series SAN Arrays combine both networking and storage functions into a single specialized  Application  Specifc  Integrated  Circuit  (ASIC). The SoC solution combines 10Gbps iSCSI, TCP & IP offoad, embedded processors, and  storage  virtualization frmware onto a  single chip. The  tight  integration of  these  functions eliminate  interoperability,  timing, and support  issues  found in competitive products that offer “discrete implementation” wherein  a  chassis,  a  main  motherboard,  a  RAID  storage controller,  iSCSI  software  or  controller,  network  interface cards,  and  operating  system  software  are  choosen separately and  then assembled. The DSN-2000 Series SAN Array outperforms these discrete implementations and does so at a lower price point. It also delivers mission critical data quickly with state-of-the-art reliability.
RAID for Effciency
The  DSN-2000  Series  SAN  Array  platform  features  8  hot swappable Serial ATA (SATA) disk drive bays supporting 8TB raw capacity using 1TB hard drives (and even higher capacity hard  drives  as  they  are  introduced)  in  RAID  level  0,  1,  1+0 and  5  confgurations.  You  can  quickly  deploy  a  SAN  using inexpensive SATA disk drives and, depending on your growing storage needs, you can simply add more drives as you go. Embedded Centralized Storage Management The  embedded  user-friendly  IP-SAN  Device Manager  (IDM) provides comprehensive storage network management. Boasting a  rich  set  of management  features,  this  suite  of  utilities  allow monitoring and control of your SAN via the SMI-S (Storage Management  Initiative)  command  set.  Combined  with  an embedded secure server, users will be able to remotely confgure and monitor their SAN storage subsystems.
Advanced Management Features
The DSN-2000 Series SAN Array provides additional advanced features  for  effcient  management  of  network  storage  and optimal performance.
Cache Management: Provides adaptive and persistent cache management. This provides write-back, write-through, write coalescing, and multi-stream read-ahead on a volume basis. This  optimizes  cache  utilization  and  performance  in  an application dependent manner.
Põhiomadused
Pesad kõvaketaste jaoks
8 (kõvakettad komplektis ei sisaldu)
Kõvaketaste liidesed
SATA-II
Süsteemimälu
256 МB kuni 512 МB (standart 512 МB)
Vahemälu
256 МB kuni 4 GB (standart 512 МB)
Vahemälu aku
Standartne (miinimum 72 tundi täislaetuna)
Läbilaskeriba
Kuni 425 Мbit/s
Kettaruumi maht
Rohkem kui 8 ТB kasutades 1TB kõvakettad (seade toetab suurema mahuga kõvakettaid)
Operatsioonisüsteemide toetus
  • Windows Vista® 32- ja 64-bitine versioon (Ultimate ja Enterprise) sisseehitatud iSCSI initsiaatoriga
  • Windows® Server 2003® SP1 32- ja 64-bitine versioon (Ultimate ja Enterprise) sisseehitatud iSCSI versiooni 2.04 initsiaatoriga
  • Windows Server 2003 R2 32- ja 64-bitine versioon (Standard ja Enterprise) sisseehitatud iSCSI versiooni 2.04 initsiaatoriga
  • Windows XP Pro 32- ja 64-bitine versioon sisseehitatud iSCSI versiooni 2.04 initsiaatoriga
  • Windows 2000 Advanced Server sisseehitatud iSCSI versiooni 1.6 ja 2.01 initsiaatoriga
  • Fedora® Core® 6 & 7
  • Red Hat® 7.3
  • Red Hat 9
  • Red Hat Enterprise® WS 3 update 4
  • Red Hat Enterprise ES 4 update 4 ja 5, 32- ja 64-bitine versioon
  • Red Hat Enterprise AS update 4
  • SuSE® Professional 9.3, 32- ja 64-bitine versioon
  • OS X® (10.4.7 | 10.4.8 | 10.4.10) protsessorite Intel® ja Power PC jaoks
    NIC, iSCSI ja iSCSI HBA kiirendite toetus
  • Intel® Pro 1000MT & XT [1GbE]
  • Intel Pro 10000 CX4 [10GbE]
  • Chelsio® S210X-SR-XFP (S2iO) [10GbE]
  • Neterion® Xframe® II & Xframe E [10GbE]
  • Alacritech® SES2104ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
  • Alacritech SES2102ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
  • QLogic® 4010C
  • QLogic 4052C
    iSCSI võrguliides
  • iSCSI võrguliides: 4 Gigabit Ethernet vask porti
  • Host-liides: iSCSI Draft 20 initsiaator
  • Ühendamine: 1024 hosti
  • CHAP autentimine
  • Ligipääsu juhtimine
  • iSCSI/TCP/IP Full HW Offload
  • Jumbo-freimide toetus
  • LAG (Link Aggregation Group) toetus: kuni 8 LAG
  • VLAN toetus: Kuni kaheksa (8). Ühetähenduslik vastavus alamvõrgu IP ja VLAN vahel. Füüsilise pordiga 802.1Q VLAN toetus. Kõik füüsilised LAG pordid kuluvad ühte VLAN
    Köidete ja RAID toetus
  • RAID kontroller: Üks, ASIC sisse integreeritud
  • RAID tasemete toetus: RAID 0, 1, 1+0 ja 5 (vaheldamine, peegeldamine, peegeldamine ja vaheldamine, paarsus)
  • Köided: 1024 virtuaalset köidet (256 saadavad initsiaatori kaudu)
  • Ühendavate sõlmede arv: 1024
  • Kettaruumi suurendamine online
  • Hot swap
  • Momentaalne kõvaketastele ligipääs
  • Vaba ruumi degragmenteerimine
  • Ketta vigade automaatne tuvastamine
  • Varuketta automaatne taastamine
  • RAID taseme teisaldamine
  • Ketaste rouming toide väljalülitamisel
  • Mikrotaastamine
    Juhtimine
  • Sisseehitatud juhtimisliides IP-aadressi baasil:
    • Loomine, juhtimine, suurendamine ja kontroll kettaruumide, köidete ja RAID eest
    • Sündmuste manager
  • Püsivara uuendamine
  • SMI-S versioon 1.1
Füüsilised parameetrid
Toiteallika tüüp
Varutoiteplokk 2U 400 W
Sisendpinge
100-240 V vahelduvvoolu
Sisendpinge sagedusdiapasoon
47-63 Hz
Nominaalne sisendvool
8 A max 100 V vahelduvvoolu jaoks ja 4A max 240 V vahelduvvoolu jaoks
PFC
95%@110 V, täiskoormus
Tarbitav võimsus
360 W (täisvõimsusel)
Soojuse eraldumine
1260 BTU /t (täisvõimsusel)
Töötemperatuur
0° kuni 40° C
Säilitamistemperatuur
-20° kuni 70° C
Tööniiskus
20 kuni 90% ilma kondensatsioonita
Säilitamisniiskus
10 kuni 95% ilma kondensatsioonita
Form-faktor
Laius 19” kõrgus 2U
Mõõdud
63.5 (L) x 48.3 (P) x 8.9 (K) mm
Kaal
20.4 kg (täiskomplekt)
Sertifikaadid
Kiirgus
CE Class A, FCC Class A, C-Tick Class A,
VCCI Class A
Turvalisus
CSA 60950-1, UL60950-1, IEC 60950-1, EN 60950-1
Sertifikaadid
Sidustooted
Pildid
DSN-2100-10
Tagantvaade
Eestvaade
Failid
Vaadake samuti
