DIB-360EOL EOS
Android-based Multimedia Platform
Kirjeldus
Working with multimedia content
The D-Link DIB-360 Android-based multimedia platform is a media player that connects to your TV to playback on its big screen digital media content*, stored on a computer, USB drive or network. With an intuitive interface, remote control and customizable media application that is provided by providers, this device allows you to enjoy watching videos and listening to your favorite music. Android-based Multimedia platformcan play video*, music and photos from a folder or a shared drive on the network, or USB drive connected to the DIB-360. This device is also equipped with a slot for SD, which allows to insert the SD card and instantly start watching a slide show of photos on the TV.
A wide range of applications
Android OS multimedia platform DIB-360 allows Internet service providers to install and provide their subscribers with customized media applications. In addition, DIB-360 contains a number of built-in applications, which further expand the possibilities of working with multimedia content and social networks. The platform supports the AUPEO! application for personal listening to Internet radio. CloudGallery application allows the user to gain access to your photos on Facebook and Picasa, making it convenient to download and view photos.
Ease of installation and ease of use
DIB-360 supports wireless standard, 802.11n, which simplifies installation of media player and allows you to reduce the number of cables used to connect. Simply connect the power adapter, and then connect the DIB-360 to your television via HDMI. After a quick setup of wireless network, taking the remote control, you can start watching movies from the Internet or from a library of digital media content.
Põhiomadused
Scope of delivery
• Android-based multimedia platform
• Remote control with battery
• Power Adapter, 5V/2A
• Installation Guide
• Warranty Card
Language Support
• English
• Spanish
• Russian
• Traditional Chinese
• Simplified Chinese
Network Protocol Support
• IPv4, ARP, TCP, UDP, ICMP
• IPv6
• DHCP-Client
• DNS-client
• HTTP
• Samba-client
• DLNA
Android™ technology
• Android™ 2.3
• Applications Android™**
Device Interfaces
• HDMI 1.3a port with HDCP
• MDI/MDIX 10/100Base-TX port
• 802.11n/g/b wireless network with WPA2/WPA/WEP encryption
• 2 USB 2.0 ports
• Optical interface for digital audio (SP/DIF)
Support for memory cards
• SD/SDHC
Image Resolution
• Up to 1080p Full HD
Indicators
• System Status
• The wireless network
• Ethernet
Sertifikaadid
Sidustooted
DIB-360 Android-based Multimedia Platform
