DCS-3420EOL EOS
Securicam Network traadita 2.4 GHz (802.11g) Internet-kaamera öisel ajal filmimise võimalusega
Kirjeldus
The DCS-3420 Wireless Day & Night Internet Camera is a versatile security system that allows you to watch and listen remotely from anywhere. This full-featured camera connects to Ethernet wired and wireless networks in a building or campus, and via broadband to the Internet. Equipped with a high-quality CCD sensor, digital zoom, low-light / no light capabilities, and advanced software functions for multi-camera monitoring and management, this camera provides a comprehensive system for surveillance over a LAN or the web.
An integrated CPU and Web server allow the DCS-3420 Internet Camera to provide a low-cost solution for home, office, and factory security monitoring needs. Its integrated Web server
eliminates the need to connect the camera to a computer. Once installed, you can use the default IP address to gain access to the camera, view live streaming video, and make changes to camera settings.
 In order to ease migration from traditional analog CCTV surveillance to IP-based digital systems, the DCS-3420 includes a standard BNC connector for analog CCTV video. The inclusion of both Ethernet and BNC connections allows you to simultaneously incorporate the DCS-3420 into both digital and analog surveillance systems. The camera also has a heat-dissipating aluminum body that is long-lasting even under the stresses of outdoor use.
The DCS-3420 uses MPEG-4 Simple Profile Mode to stream live video at up to 30 frames per  second for real-time viewing. A CCD sensor provides sharp video images with lifelike color representation, and a 4x digital zoom* capability allows for close-up viewing over the Web interface.  Using optional low-light / no light attachments, the camera has the ability to monitor and record video in rooms with minimal or no lighting, making it ideal for use in dark places.
Through a built-in microphone, you can watch and listen remotely as the DCS-3420 captures both sound and video from your site. The DCS-3420 takes surveillance to another level using two-way audio. By adding a powered speaker (not included) to the DCS-3420, you can also talk remotely with anyone at your camera site. For effective surveillance in and around a building, this camera comes with a built-in high-speed 802.11g wireless network interface, which allows images to be transmitted at up to 54Mbps. A 10/100BASE-TX Ethernet port is also provided for  connection to a wired Ethernet network or directly to the Internet via a broadband router.
The DCS-3420 adheres to the Universal Plug-n-Play specification, which allows computers running Windows XP/ME to automatically recognize the camera and add it to the network. The DCS-3420 can be accessed and viewed from any network space.
Everything needed to deploy the DCS-3420 camera is included. Simple installation procedures, along with the built-in Web-based interface, offer easy integration into your network and security systems
Põhiomadused
Kaamera omadused
  • Sisseehitatud 1/3-tolline CCD sensor
  • Minimaalne valgustatus: 0.5 Lux @ f2.0
  • 0 Lux (kuni 10 m lisa infrapuna anduriga)
  • Resolutsioon: 380 TV-rida
  • 4-x digitaalsuum
  • AGC / AWB / AES / BLC
  • Elektroonne objektiivi lukk: 1/60 ~ 1/100,000 sekundit
  • Eemaldatav lääts CS: 6 mm, f2.0
  • Vaatenurk 66°
    Indikaator
  • Üks kahevärviline oleku indikaator (POST, ühendus, töö)
    Reset nupp
  • Tehasesätete taastamise nupp
    Lisa sisendid ja väljundid
  • 1 signalisatsiooni releeväljund (maksimaalne alalisvool 24 V / 1 А, vahelduvvool 125 V / 0,5 А)
  • 1 optiline isoleeritud sisendandur (maksimaalne alalisvool 12 V / 50 mА)
    Mälu
  • SDRAM: 16 MB
  • Flash ROM: 4 МB
    Resolutsioon
    NTSC toetus:
  • kuni 30 kaadrit/s resolutsioon 176 x 120 (NTSC)
  • kuni 30 kaadrit/s resolutsion 352 x 240 (NTSC)
  • kuni 15 kaadrit/s resolutsioon 704 x 480 (NTSC)
    PAL toetus:
  • kuni 25 kaadrit/s resolutsioon 176 x 144 (PAL)
  • kuni 25 kaadrit/s resolutsioon 352 x 288 (PAL)
  • kuni 12 kaadrit/s resolutsioon 704 x 576 (PAL)
    Video kompressimise algoritmide toetus
  • MPEG4 simple profile või MJPEG
  • JPEG
    Video omadused
  • Pildi suuruse ja kvaliteedi reguleerimine
  • Teksti ja ajamärgised
  • Kolm seadistatavat liikumise tuvastamise akent
  • Pildi pööramine ja peegeldamine
    Audioväljund
  • Oma audiokoodek 8-32 Kbit/s
  • 2-poolne heli edastamine, mono, simpleks-, pooldupleks- ja täisdupleksrežiimi toetus
  • Mikrofoni sisse-/väljalülitamine
  • Kõlarite sisse-/väljalülitamine
  • Helitugevuse häälestamine
    Mikrofon
  • Ringsuunaline
  • Sagedusdiapasoon 20 kuni 20000 Hz
  • Signaal/müra suhe 58 dB
    Heli
  • Täisdupleks heli edastus
  • Kaja mahasurumine
    Ühendus
  • 802.11g WLAN
  • 802.3 10/100 Мbit/s Fast Ethernet NWay toetusega
    Võrguprotokollide toetus
  • UPnP, TCP/IP, HTTP, SMTP, FTP, NTP, DNS, DDNS, DHCP, PPPoE
    Lisa protokoll
  • SMTP Authentication
    Häälestamine
  • Liikumise tuvastamine 3 akent
  • 2 seadistatavat parameetrit: tundlikkus ja protsentuaalne suhe
    Digitaalsisend
  • Oleku kontrollimine: high, low, rising, falling
  • Signaliseerimine liikumisanduri või välise anduri reageerimisel, teatiste saatmine FTP-le või e-mailine
    Digitaalväljund
  • Sisselülitamine/Väljalülitaminie
    Video edastuskiirus
  • 64 ~ 1200 Kbit/s
    Kaugjuhtimine
  • Häälestamine veebibrauseri kaudu
  • Piltide saamine ja nende salvestamine lokaal kõvaketta peale veebibrauseri kaudu
    Turvalisus
  • Administraatori ja kasutajagruppi kaitsmine
  • Autentimine parooli järgi
  • Juhtmavaba võrgu turvalisus: 64/128-bitine WEP ja WPA-PSK andmekrüpteerimine
    Jälgimistarkvara funktsioonid
  • 16 kaamerate eemalt juhtimine/kontroll
  • Kuni 16 kaamera pildi kuvamine ühel ekraanil
  • Kõikide juhtimisfunktsioonide toetus veebiliideses
    Nõuded süsteemile (pildi jälgimiseks)
  • Operatsiooni süsteem: Microsoft Windows 98 SE, 2000, ME, XP
  • Veebilehitseja: Internet Explorer v.6.0 või uuem
    Lisa
  • Autodiafragmaga lääts (3-х optiline suum)
  • Infrapuna lääts
  • Lamp vähese valgustusega oludele
  • Välised kõlarid
  • Väline ilmastikukindel korpus (ühedamine ainult Ethernet kaabli kaudu)
    Juhtmevaba võrk
    Raadio skeemid ja modulatsioon
  • 802.11b: DQPSK, DBPSK и CCK
  • 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
    Sagedusdiapasoon
  • 2.4 kuni 2.4835 GHz
    Andmeedastuskiirus
  • 802.11b: 11, 5.5, 2 и 1 Mbit/s
  • 802.11g: 54, 48, 36, 24, 18, 12, 9 ja 6 Mbit/s
    Vastuvõtja tundlikkus
    802.11b:
  • 11 Mbit/s (CCK): -84 dBm
  • 5.5 Mbit/s (CCK): -86 dBm
  • 2 Mbit/s (DQPSK): -88 dBm
  • 1 Mbit/s (DBPSK): -90 dBm
  • (tavaline@PER < 8% paketi suurus 1024 ja @25 C + 5 C)
    802.11g:
  • 54 Mbit/s (OFDM): -66 dbm
  • 48 Mbit/s (OFDM): - 70 dbm
  • 36 Mbit/s (OFDM): -76 dbm
  • 24 Mbit/s (OFDM): -79 dbm
  • 18 Mbit/s (OFDM): -83 dbm
  • 12 Mbit/s (OFDM): -85 dbm
  • 9 Mbit/s (OFDM): -86 dbm
  • 6 Mbit/s (OFDM): -86 dbm
  • (tavaline@PER <10% paketi suurus 1024 и @25 C + 5 C)
    Saatja võimsus
  • 802.11b: 16 dBm (tüüpiline)
  • 802.11g: 12 dbm (tüüpiline)
    Antenn
  • Väline dipoolantenn võimendusteguriga 2 dBi (reverse SMA ühenduspistik)
  • Sertifikaadid
    Sidustooted
    DCS-3420   Day and Night Audio/Video Monitoring
    Pildid
    DCS-3420/A
    Eestvaade
    Vasakvaade
    Tagantvaade
    Failid
    Vaadake samuti
