DCS-56PEOL EOS
PoE Outdoor Enclosure
Kirjeldus
The DCS-56 Series Outdoor Enclosure is an outdoor enclosure designed for use with D-Link’s box cameras. This IP66-certified enclosure protects your camera against dust and heavy jets of water. The DCS-56 series consists of the DCS-56, DCS-56P and DCS-56W. These models include a heater and a blower for a wider range of temperature-sensitive environments.
Weather-proof Operation
Designed to be mounted outdoors, the DCS-56 Series Outdoor Enclosure protects your D-Link cameras from the vigors of adverse weather conditions including dust and heavy jets of water. The DCS-56 Series is IP66-certified, meaning it meets highly rigorous standards for providing complete protection.
Flexible Model Options
The DCS-56 Series features 3 models - the DCS-56, the DCS-56P, and the DCS-56W. While all three models boast IP66-certified enclosure and durable usage, the DCS-56P features PoE (Power over Ethernet), in which electric power is transmitted  over an Ethernet cable along  with data. This allows the DCS-56P model to be easily installed in a variety of locations without  the need for power cabling. The DCS-56W is equipped with wireless antennas that allow the camera to be controlled and monitored wirelessly, avoiding the need to install Ethernet wiring.
Onboard Heater and Blower
The DCS-56 Series Outdoor Enclosure also has an onboard heater and blower that enable the enclosed camera to function in a wide range of temperatures in both hot and cold environments. The heater automatically turns on when the temperature drops below a certain point, and the blower automaitcally turns on when the temperature rises above a certain point.
Põhiomadused
Casing Material
Aluminium Zinc Alloy
Weatherproof
IP66
Wireless Antenna
No
Heater
On: 0 °C; Off: 10 °C
Blower
On: 40 °C; Off: 30 °C
Transmission Rate
10/100 Mbps
Transmission Distance
Up to 100 meters
Ethernet Data Cable
TIA/EIA-568, Cat 5 Cable
Sertifikaadid
Sidustooted
DCS-56P  PoE Outdoor Enclosure
Pildid
DCS-56P/A
Eestvaade
Failid
Vaadake samuti
