DNR-202LEOL EOS
mydlink IP kaamera videosalvesti
Kust osta
Kirjeldus
The DNR-202L mydlink Camera Video Recorder is a home Network Video Recorder (NVR) which records from up to 4 IP cameras to locally attached USB storage. The DNR-202L is an efficient and reliable consumer oriented, plug-and-play NVR with a user-friendly GUI that greatly simplifies network and camera setup. With powerful management for your IP cameras, video recording, playback and storage the DNR-202L provides high-quality remote monitoring functionality and serves as a well featured digital replacement for older surveillance systems.
mydlink Technology on your Mobile Device
Empowered with mydlink technology, the DNR-202L enables users to remotely view and manage mydlink enabled devices from anywhere via a web browser using the mydlink website or the NVR’s web interface. Additionally the mydlink View NVR app means you can access and monitor your DNR-202L from your mobile devices.
Convenient and Reliable Video Recording
The DNR-202L can manage multiple network cameras, providing direct access to view live video and play recorded data over the Internet from anywhere, anytime. Complete video management and the ability to playback and record new video simultaneously, the DNR-202L is an extremely convenient and effective video recorder. Moreover, the light weight, portability and small size of the DNR-202L make it easy to deploy in any location.
Versatile Monitoring and Adjustment
Users have a variety of options for viewing and organizing saved recordings on-screen. Helpful, user-friendly camera names and recording statuses can be displayed via the on-screen display. Single or Multiple cameras may be viewed on-screen and users can also control pan/tilt/zoom (PTZ) functions from within the interface.
Automatic Camera Discovery
Finding and configuring your IP cameras couldn’t be easier. Simply press the auto-scan button and the DNR-202L will find all the cameras connected to your network. The DNR-202L’s built in buzzer will beep to confirm each of the cameras it finds.
Extensive recording functionality
The DNR-202L uses clear and simple interface enabling users to quickly and easily configure the most common settings, including compression, resolution, and frame rate for all connected cameras. Once the cameras have been set up, recordings can be made automatically.
Põhiomadused
Video Format
• H.264/MPEG-4/MJPEG for live streaming
• JPEG for still images
Audio support
• G.711
• G.726
Reset Button
• Reset to factory default
Auto Scan Key
• IP Camera Finder (press for 3 seconds)
External Device Interfaces
• 10/100 BASE-TX Fast Ethernet port
• 2 x USB 2.0 ports for external HDD storage
Live View Resolution
• 1280 x 720 (1 channel)
• 640 x 480 (4 channels)
Live View Display Modes
• 1 and 4 channels display
Recording Modes
• Schedule, Manual, Event (Motion)
• Continuous
Recording Performance
• 32 Mbps
Playback Modes
• Time, Event, Camera
Playback Performance
• Max. 720P  for 1 channel
Playback Control
• Play, Stop, Pause, Forward, Backward, Next, Previous
Video Export Formats
• AVI
Physical Interface
• RJ45 10/100 LAN Ethernet (auto MDI/MDIX)
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP Client
• DNS Client
• HTTP Server
• HTTPS
• SMTP
• RTP
• RTCP
• RTSP
• NTP
• UPnP
User Management
• Adminstrator password authentication
Automatic Logoff
• Idle user timeout on configuration pages
System Requirements
• Microsoft Windows: XP SP3, Vista, 7, 8
• Mac OS X 10.5 or later
Browser Requirements
• Internet Explorer 8 or higher
• Firefox, Chrome, Safari
Mobile Support
• Android
• iOS
Remote Management
• Take snapshots/video via web browser
• Configuration interface accessible via web browser
System Log
• Status of active users
• Login history
Certifications
• CE
• FCC
• CE LVD
• C-Tick
Füüsilised parameetrid
Weight
• 90 g
External Power Adapter
• Input: 5 V DC, 3 A
• Consumption: 8.5 watts ± 5 % (include 2 x 2.5 HDD)
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Storage: 5% to 95% non-condensing
Dimensions
Sertifikaadid
Sidustooted
Pildid
DNR-202L
Eestvaade
Paremvaade
Vasakvaade
Tagantvaade
Failid
Vaadake samuti
