Toote omadused:
Vigilance HD Wireless Camera
The DCS-4201 Vigilance HD Wireless Camera is a versatile surveillance solution that is perfect for monitoring in your home or small office. It combines a high-resolution megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness. The DCS-4201 also includes a built-in IR cut filter, making it suitable for both day and night applications. Additionally, the DCS-4201 is a complete system with a built-in CPU and web server that transmits high-quality video images for security and surveillance. The DCS-4201 features 802.11n wireless, allowing the camera to be placed anywhere within range of your wireless network.
A Complete, Expandable Surveillance Solution
The DCS-4201 is a self-sufficient surveillance solution, capable of recording snapshots and video to a microSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Built for Versatility
The DCS-4201 comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send you a notification when motion is detected. A built-in microphone and speaker allow for 2-way communication, which is ideal for use in entryways or for caretaker applications.
ePTZ For Surveying Regions Of Interest
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera’s  megapixel  resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
Wireless N Connectivity
The Vigilance HD Wireless Camera includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream high quality video to remote sites and mobile devices. The DCS-4201 also includes a standard Ethernet port for connections to traditional wired networks.
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
