Kiirotsing
Toote omadused:
Omna 180 Cam HD
Põhiomadused:
Hardware Profile
• 1/3” 3 Megapixel progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination:
  0.3 lux (IR off; color mode)
  0 lux (IR on; B/W mode)
• Built-in Infrared-Cut Removable (ICR) Filter module
• Aperture: F2.0
• Angle of view:
  (H) 180°
  (V) 66°
  (D) 180°
• Built-in microphone and speaker (5-meter range)
Camera Housing
• Aluminum housing
LED Indicators
• Power/Status LED
Image Features
• Automatic image size and quality adjustment based on network quality***
• Configurable motion detection windows
• Pre-event recording
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 SRTP streaming
Video Resolutions
• 16:9 - 1920 x 1080,1280 x 720, 640 x 360 up to 30 fps
Audio Compression
• AAC
External Device Interface
• microSD card slot****
Network Protocols
• IPv6
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• Bonjour
• HTTPS configuration
Wireless Security
• WPA/WPA2-PSK
Event Management
• Motion detection
• Event notification
Mobile Support
• OMNA mobile app for iPhone, iPad, iPod Touch
Physical Parameters
Weight
• 232 grams
Dimensions
• Diameter: 58 mm
• Height: 132.2 mm
External Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 5 V DC, 2 A
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20 to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• ICES
• SRRC
• TRA
• VCCI
• FCC
• NCC
• KCC
• C-Tick
* To control this HomeKit-enabled accessory automatically and away from home, an Apple TV with tvOS 10.1 or later or an iPad with iOS 10.1 or later and an iPhone or iPad with iOS 10.1 or later is recommended.
** Notification transmission may be dependent on network stability and other extraneous factors.
*** The resolution and frame rate will be adjusted automatically based on network quality. The quality of HD streaming is dependent on network bandwidth.
**** A microSD card is not included. SDHC Class 10 is recommended.
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
