Kirjeldus
PRODUCT DESCRIPTION
The DCS-910/920 is a versatile and unique surveillance solution for your small offce or home. Unlike a standard webcam, the DCS-910/920 is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance. The DCS-910/920 can be accessed remotely and controlled from any PC or notebook over the local network or through the Internet via a web browser. The simple installation and intuitive web-based interface offer easy integration with your Ethernet/Fast Ethernet or 802.11g wireless network. The DCS-910/920 also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
WIRELESS G CONNECTIVITY
The DCS-920 offers both 802.11g wireless and Ethernet/Fast Ethernet connectivity, making the DCS-920 easy to integrate into your existing network environment. The DCS-920 works with a 10Mbps Ethernet based network or a 100Mbps Fast Ethernet based network for traditional wired environments and works with 802.11g routers or access points for added fexibility. The Site Survey feature also allows you to view and connect to nearby wireless networks.
Põhiomadused
- Toetatavad operatsioonisüsteemid
- Windows 2000 / Windows XP /Windows Vista / Linux/ MAC OS X10.3 või uuem
- Utility
Võrguprotokollid - IPV4, ARP, TCP, UDP, ICMP
- DHCP Client
- NTP Client
- DNS Client
- DDNS Client
- SMTP Client
- FTP Client
- HTTP Server
- PPPoE
Sisseehitatud võrguliides - 10/100BASE-TX Fast Ethernet
Video koodekid - MJPEG
Sensor - CMOS VGA ¼ tolli
SDRAM - 8 MB
FLASH-mälu - 2 MB
RESET nupp - Tehasesätete taastamine
Video algoritmide toetus - MJPEG
- JPEG stop-kaadrite jaoks
Video funktsioonid - Pildi suuruse ja kvaliteedi häälestamine
- Teksti- ja ajamärgised
- Pildi pööramine ja peegeldamine
Resolutsioon - 640 х 480 kuni 15fps
- 320 х 240 kuni 30fps
- 160 х 120 kuni 30fps
Valgustatus - 1 lux @F2.8
Juhtimine - AGC (Auto Gain Control)
- AWB (Auto White Balance)
- AES (Auto Electronic Shutter)
