DCS-920EOL EOS
Juhtmevaba Securicam Network IP-kaamera kodu/büroo eemalt jälgimiseks
Kust osta
Kirjeldus
DUCT DESCRIPTION
The DCS-910/920 is a versatile and unique surveillance solution for your small offce or home.  Unlike a standard webcam, the DCS-910/920 is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance.  The DCS-910/920 can be accessed remotely and controlled from any PC or notebook over the local network or through the Internet via a web browser.  The simple installation and intuitive web-based interface offer easy integration with your Ethernet/Fast Ethernet or 802.11g wireless network.  The DCS-910/920 also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
WIRELESS G CONNECTIVITY
The DCS-920 offers both 802.11g wireless and Ethernet/Fast Ethernet connectivity, making the DCS-920 easy to integrate into your existing network environment.  The DCS-920 works with a 10Mbps Ethernet based network or a 100Mbps Fast Ethernet based network for traditional wired environments and works with 802.11g routers or access points for added fexibility.  The Site Survey feature also allows you to view and connect to nearby wireless networks.
Põhiomadused
 Toetatavad operatsioonisüsteemid
  • Windows 2000 / Windows XP /Windows Vista / Linux/ MAC OS X10.3 või uuem
  • Utility
    Võrguprotokollid
  • IPV4, ARP, TCP, UDP, ICMP
  • DHCP Client
  • NTP Client
  • DNS Client
  • DDNS Client
  • SMTP Client
  • FTP Client
  • HTTP Server
  • PPPoE
    Sisseehitatud võrguliides
  • 10/100BASE-TX Fast Ethernet
  • 802.11b/g WLAN
    Juhtmevaba ühendus
    802.11b/g Wireless with WEP/WPA/WPA2 security
    Saatja väljundvõimsus
  • 16 dBm (tüüpiline) 802.11b jaoks
  • 12 dBm (tüüpiline) 802.11g jaoks
    Vastuvõtja tundlikkus
  • 802.11g (PER<10%) - 54 Мbit/s: <-66dbm
  • 802.11b (PER<8%) - 11 Мbit/s: <-82dbm
    Video kodekid
  • MJPEG
    Sensor
  • CMOS VGA ¼  tolli
    SDRAM
  • 8 MB
    FLASH-mälu
  • 2 MB
    RESET nupp
  • Tehasesätete taastamine
    Toatatavad video algoritmid
  • MJPEG
  • JPEG stop-kaadrite jaoks
    Video funktsioonid
  • Pildi suuruse ja kvaliteedi häälestamine
  • Teksti- ja ajamärgised
  • Pildi pööramine ja peegeldamine
    Resolutsioon
  • 640 х 480 kuni 15fps
  • 320 х 240 kuni 30fps
  • 160 х 120 kuni 30fps
    Valgustatus
  • 1 lux @F2.8
    Juhtimine
  • AGC (Auto Gain Control)
  • AWB (Auto White Balance)
  • AES (Auto Electronic Shutter
  • Füüsilised parameetrid
      Toide
    • Sisendil: 100-240 V vahelduvvool, 50 / 60 Hz
    • Väljundil: 5 V alalisvool 2,5 А
    • Väline toiteadapter
      Mõõdud
      71,9 mm х 110,0 mm х 37 mm
      Kaal
      231 g
      Tarbitav võimsus
      3,25 W
      Töötemperatuur
      0° kuni 40°C
      Säilitamistemperatuur
      -20° kuni 70°C
      Niiskus
      20 kuni 80% ilma kondensatsioonita
      Sertifikaadid
      + FCC Class B
      + IC
      + C-Tick
      + CE
    Sertifikaadid
    Sidustooted
    DCS-920   802.11g Wireless Internet Camera
    Pildid
    DCS-920
    Tagantvaade
    Eestvaade
    Failid
    Vaadake samuti
