Kiirotsing
Toote omadused:
Mini Powerline AV 500 Adapter sisseehitatud pistikupesaga (passthrough)
Põhiomadused:
Interfaces
• Powerline: power connector (depending on country)
• Passthrough: power connector (depending on country)
• Ethernet: Fast Ethernet port with RJ-45
Standards
• IEEE 802.3
• IEEE 802.3u
• HomePlug AV
• IEEE 1901
Safety
128-bit AES data encryption
Indicators
• Power
• Ethernet
• Powerline
The modulation scheme Powerline
Symbol OFDM modulation
Bandwidth Powerline
From 2 MHz to 30 MHz
Data rate
• Powerline: 200 Mbit / s (physical rate) 2
• Ethernet: 10/100 Mbit / s (Auto-Negotiation)
Füüsilised parameetrid
Measurements
91,5 x 62 x 35,5 mm
Saving energy
Support power saving mode
Temperature
Working from 0 to 40 C
Humidity
Operating: 10% to 90% (non-condensing)
Certifications
• CE LVD
• FCC
• UL
• CE EMC Class B
• RoHS
• ErP
Electrical outlet (depending on country)
• Electrical outlet type EU: 250 V / 16 A max
• Electrical outlet type UK: 250 V / 13 A max.
• Electrical outlet type FR: 250 V / 16 A max
• Electrical outlet type US: 125 V / 12 A max
• The electrical socket type AU: 250 V / 10 A max
Power Input
100-240 VAC
2 Products Powerline AV + are equipped with more powerful CPU than providing data transfer rate 200 Mbit / s products Powerline AV, to increase performance. Maximum throughput based on theoretical transmission PHY rate of the data. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, and network overhead, lower actual throughput. Interference from devices that produce electrical noise, such as vacuum cleaners and hair dryers can reduce the performance of the product. This product may cause interference and prevent the operation of devices such as lighting with dimmer switch or a touch-button on / off switch, short wave radio communication devices or other devices Powerline, do not meet the standard HomePlug AV.
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
