DAP-2590EOL EOS
Kirjeldus
Overview
The D-Link DAP-2590 AirPremier N Dual Band PoE Access Point provides businesses with a solution for deploying next generation draft 802.11n local area networks (LANs). Designed specifcally for business-class environments, such as large or enterprise corporations, this access point provides secure and manageable dual band wireless LAN options for network administrators.
Versatile Access Point
The DAP-2590 AirPremier N Dual Band PoE Access Point allows network administrators to arrange a highly manageable and extremely robust dual band wireless network. All three detachable dual band antennas supply optimal wireless coverage in either 2.4GHz (802.11g and draft 2.0 802.11n) or 5GHz (802.11a and draft 2.0 802.11n) frequency bands. Enclosed in a plenum-rated metal chassis, the AirPremier N Dual Band PoE Access Point adheres to strict fre codes for placement in air passageways. For advanced installations, this high-speed access point has integrated 802.3af Power over Ethernet (PoE) support, allowing installation of this device in areas where power outlets are not readily available.
Enhanced Performance
The DAP-2590 delivers reliable wireless performance with maximum wireless signal rates of up to 300Mbps in either the 2.4GHz or 5GHz wireless band. Support for the Wi-Fi Multimedia™ (WMM) Quality of Service feature, makes it an ideal access point for audio, video, and voice applications. Additionally, this access point supports load balance features to ensure maximum performance.
Security
To help maintain a secure wireless network, the AirPremier N Dual Band PoE Access Point provides the latest in wireless security technologies by supporting both Personal and Enterprise versions of WPA and WPA2 (802.11i) with support for RADIUS server backend. This access point also includes MAC Address Filtering, Wireless LAN segmentation, Disable SSID Broadcast, Rogue AP Detection, and Wireless Broadcast Scheduling to further protect your wireless network.
The AirPremier N Dual Band PoE Access Point includes support for up to 8 VLANs for implementing multiple service set identifers (SSIDs) to further help segment users on the network. The DAP-2590 also includes a wireless client isolation mechanism to limit direct client-to-client communication.
Multiple Operation Modes
The DAP-2590 can be confgured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS/Bridge (No AP Broadcasting) and Wireless Client. With WDS support, network administrators can set up multiple DAP-2590s throughout a facility and confgure them to bridge with one another while also providing network access to individual clients. Also included are advanced features such as Load Balancing, which optimizes high network traffc volume, and redundancy for fail-safe wireless connectivity. Spanning Tree Protocol support allows greater effciency and avoids broadcast storms when used in WDS mode.
Network Management
Network administrators have multiple options for managing the AirPremier N Dual Band PoE Access Point including Web (HTTP), Secure Sockets Later (SSL, which provides for a secure connection to the Internet), Secure Shell (SSH, which provides for a secure channel between local and remote computers), and Telnet (bi-directional, eight-bit byte oriented communications facility). For advanced network management, administrators can use the D-Link AP Manager II or D-View SNMPv3 management module to confgure and manage multiple access points from a single location. In addition to a streamlined management process, the AP Manager II or D-View software provides network administrators with the means of verifying and conducting regular maintenance checks without wasting resources by sending personnel out to physically verify proper operation.
With the selectable dual band functionality, PoE support, plenum-rated chassis, extensive manageability, versatile operation modes, and solid security enhancements, the new D-Link DAP-2590 AirPremier N Dual Band PoE Access Point provides small to medium business (SMB) environments with a business-class solution for deploying a wireless network in the workplace.
Põhiomadused
Standards
- IEEE Draft 2.0 802.11n
- IEEE 802.11a
- IEEE 802.11g
- IEEE 802.3ab
- IEEE 802.3af
- IEEE 802.3u
- IEEE 802.3
Network Management
- Command Line Interface
- Telnet
- Secure (SSH) Telnet
- Web Browser Interface
- HTTP
- Secure HTTP (HTTPS)
- SNMP Support
- D-View Module
- Private MIB
- AP Manager II
Security
- WPA™ – Personal
- WPA – Enterprise
- WPA2™ – Personal
- WPA2 – Enterprise
- 64/128-bit WEP
- SSID Broadcast Disable
- MAC Address Access Control
- Wireless Frequency Range
- 2.4GHz to 2.4835GHz
- 5.15GHz to 5.25GHz and 5.725GHz to 5.85GHz
Operating Modes
- Access Point (AP)
- WDS with AP
- WDS/Bridge (No AP Broadcast)
- Wireless Client
LEDs
- Power
- 5GHz
- LAN
- 2.4GHz
Operating Voltage
48VDC +/- 10% for PoE or 5V 2.5A
Temperature
- Operating: 32 ºF to 104ºF (0ºC to 40ºC)
- Storing: -4ºF to 149ºF (-20ºC to 65ºC)
Humidity
- Operating: 10%~90% (non-condensing)
- Storing: 5%~95% (non-condensing)
Certifications
- FCC, CE
- C-Tick
- IC, UL
- Wi-Fi
Weight
762 gr
Dimensions (WxHxD)
165mm x 43mm x 185mm
