DAP-1360EOL EOS
Juhtmevaba 2,4 GHz (802.11n) pääsupunkt, kuni 300 Мbit/s
Kust osta
Kirjeldus
CONNECT HOME AND SOHO TO A WIRELESS NETWORK
Connect this Access Point to a broadband modem and wirelessly share your Internet connection. The D-Link DAP-1360 access point is a draft 802.11n compliant device that delivers up to 14x faster speeds1 and 6x farther range1 than 802.11g while staying backward compatible with 802.11g and 802.11b devices. Enjoy surfing the web, checking e-mail, and chatting with family and friends online.
PROTECT YOUR WIRELESS NETWORK AND DATA EASILY
The DAP-1360 provides 64/128-bit WEP encryption and WPA/WPA2 security to protect your network and wireless data. This device also supports WiFi Protected Setup (WPS) to quickly and securely setup a wireless network. In addition, it also provides MAC address filtering a nd the disable SSID Broadcast function to limit outsiders’ access to your home and office network.
FLEXIBLY CONFIGURE YOUR AP FOR DIFFERENT APPLICATIONS
The DAP-1360 can be configured to operate as (1) an Access Point to act as a central hub for wireless users, (2) a Wireless Client to connect to another Access Point, (3) a Bridge to joint two wireless workgroups together, (4) a Bridge with AP to act as wireless hub and a bridge at the same time, (5) a Repeater to extend the wireless coverage to cover all “dead” spots, (6) a WISP Client Router to let wireless Internet service subscribers share Internet connection with home/office Ethernet-enabled computers without the need for an extra router, or (7) a WISP Repeater to let WISP subscribers share Internet connection with wireless computers without any extra router.
EASY TO INSTALL AND USE
With D-Link Setup Wizard, you can set up your wireless network in minutes. It configures your DAP-1360’s operation mode and makes it easy to add new wireless devices onto the network, and helps you create a simple wireless network for your home and office.
Põhiomadused
Standardid
+ 802.11n
+ 802.11g
+ 802.11b
+ 802.3/802.3u 10Base-T/100Base-TX Ethernet
+ ANSI/IEEE 802.3 NWay auto-negotiation
Liidesed
+ 802.11g/n
+ 1 x 10/100Base-TX Ethernet LAN port
Sagedusdiapasoon
2,4 – 2,4835 GHz
Kanalite arv
+ FCC: 11
+ ETSI: 13
Modulatsiooni skeemid
+ DQPSK, DBPSK, CCK, OFDM
Töörežiimid
+ Pääsupunkt
+ WDS
   Sild
   Repiiter
+ Ruuter
Antenn
+ Kaks eemaldatavat ringantenni võimendusteguriga 2dBi (RP-SMA)
Turvalisus
+ 64/128-bitine WEP-andmekrüpteerimine
+ WPA-PSK, WPA2-PSK
+ WPA-EAP, WPA2-EAP
+ TKIP, AES
+ МАС-aadressi filtreerimine
+ SSID broadcast väljalülitamine
+ WPS (Wi-Fi Protected Setup)
Laiendatud funktsioonid
+ Quality of Service (QoS): Wi-Fi Multimedia (WMM)
+ IGMP Snooping
Seadme juhtimine
Web-juhtimisliides -  Internet Explorer v6 või uuem, Netscape Navigator v6 või uuem või muu veebilehitseja Java toetusega
Sagedusdiapasoon
2400 ~ 2483.5 MHz
Edastuskiirus
+ IEEE 802.11b: 11, 5.5, 2 ja 1 Мbit/s
+ IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 ja 6 Мbit/s
+ IEEE 802.11n: MCS0 kuni MCS15
Saatja väljundvõimsus
+ IEEE 802.11b: 17dBm
+ IEEE 802.11g: 15dBm
+ IEEE 802.11n: 12dBm (HT20), 10dBm (HT40)
Vastuvõtja tundlikkus
IEEE 802.11b:
-82dBm 11 Мbit/s
-85dBm 5.5 Мbit/s
-86dBm 2 Мbit/s
-86dBm 1 Мbit/s
IEEE 802.11g:
-72dBm 54 Мbit/s
-74dBm 48 Мbit/s
-78dBm 36 Мbit/s
-81dBm 24 Мbit/s
-83dBm 18 Мbit/s
-84dBm 12 Мbit/s
-85dBm 9 Мbit/s
-85dBm 6 Мbit/s
IEEE 802.11n:
HT20
-86dBm MCS0 korral
–84dBm MCS1 korral
–82dBm MCS2 korral
–80dBm MCS3 korral
–77dBm MCS4 korral
–72dBm MCS5 korral
–71dBm MCS6 korral
–69dBm MCS7 korral
–85dBm MCS8 korral
–82dBm MCS9 korral
–80dBm MCS10 korral
–77dBm MCS11 korral
–74dBm MCS12 korral
–69dBm MCS13 korral
–67dBm MCS14 korral
–65dBm MCS15 korral
HT40
–85dBm MCS0 korral
–83dBm MCS1 korral
–81dBm MCS2 korral
–78dBm MCS3 korral
–75dBm MCS4 korral
–70dBm MCS5 korral
–69dBm MCS6 korral
–67dBm MCS7 korral
–83dBm MCS8 korral
–80dBm MCS9 korral
–78dBm MCS10 korral
–75dBm MCS11 korral
–71dBm MCS12 korral
–67dBm MCS13 korral
–65dBm MCS14 korral
–63dBm MCS15 korral
Füüsilised parameetrid
Toide sisendil
+ 5 V alalisvool 2 А
+ Väline toiteadapter
Mõõdud
144 x 109 x 30 mm
Kaal
229 g
Töötemperatuur
0˚ kuni 55˚C
Säilitamistemperatuur
-10˚ kuni 70˚C
Tööniiskus
10% kuni 90%, ilma kondensatsioonita
Säilitamisniiskus
5% kuni 95%, ilma kondensatsioonita
Sertifikaadid
+ FCC Class B
+ CE
+ Wi-Fi b/g/n
1 Maksimaalne juhtmevaba ühenduse andmeedastuskiirus põhineb standard IEEE 802.11g ja 802.11n.spetsifikatsioonidel. Tegelik andmevoo läbilaskevõime võib erineda. Võrgu seisund ja keskkondlikud tegurid , sealhulgas võrguliikluse intensiivsus, võrgu konstruktsioon ja materjalid ning võrgu koormus vähendavad võrgu liikluse tegelikku läbilaskevõimet.
Sertifikaadid
Sidustooted
DAP-1360  Juhtmevaba 2,4 GHz (802.11n) pääsupunkt, kuni 300 Мbit/s
Pildid
DAP-1360
Tagantvaade
Eestvaade
Failid
Vaadake samuti
