ANT70-SPEOL EOS
Antenna Surge Protector
Kirjeldus
D-Link’s ANT70-SP is a surge protector for outdoor antennas, which protects WLAN devices from electrical surges during thunder and lightning storms. It can prevent lightning strikes and the effects of partial discharges and other electrostatic events. It includes a gas tube that can be changed for multiple uses to save costs. The ANT70-SP is vital for outdoor protection and is compatible with any of D-Link’s outdoor antennas.
Põhiomadused
Frequency Range
0-6GHZ
Impedance
50 ohms
VSWR
• 0-3GHZ: 1.3 maximum: 1
• 3-6GHZ: 1.5 maximum: 1
Insertion Loss
0.8dB(max)
Gas Tube DC Breakdown Voltage
90V ± 20%
Impulse Discharge Voltage
• 5KA min(wave 8/20 μs)
• 10KV min(wave 1.2/50 μs)
Testing Standard
IEC 1000-4-5 8/20 μs Waveform
Insulation Resistance
DC 50V > 10000MΩ
Sertifikaadid
Sidustooted
Pildid
ANT70-SP/Ax
Eestvaade
Failid
Vaadake samuti
