DAP-3860Projektideks
Kirjeldus
A wireless backhaul installation can provide network access for remote offices and academic buildings areas that cannot be reached by cable. For instance, rural medical clinics can use the system for telemedicine applications, to exchange vital patient data with city hospitals and health care centers.
Põhiomadused
	System
	• CPU
	• IXP425, 533MHz
	Memory
	• 16MB Flash
	• 32MB SDRAM (modified to 64MB)
	Power
	• Power over Ethernet (PoE Injector Output 19,3 W)
	Radio
	• Module RF *
	• FCC: XA-632AH
	• CE: AG-623C
	Operating frequency *
	• FCC: 5,725 ~ 5,850 GHz
	• CE: 5,470 ~ 5,600 GHz, 5.650 ~ 5.725 GHz
	RF modulation
	• 802.11a: OFDM (BPSK, QPSK, 16-QAm, 64-QAm)
Output power RF * • 24dBm at Radio for FCC (Band 4) • 30dBm EIRP for ETSI 301 893 (Band 3)
	Sensitivity
	• -90 dBm @ 6 Mbps / sec
	• -73 dBm @ 54 Mbit / s
	Certificates
	• FCC Class B, CE, IC, C-Tick, NCC
	Operation / Software
	• Operating Modes
	• Bridge
	Security
	• WEP64/128/152, WPA-PSK/WPA2-PSK, TKIP, AES
	Bandwidth Management
	20MGts/40MGts
	Super A / G
	• Technology Fast Frames, Bursting, Compression
	Link Aggregation
	• Increased capacity
	Intel TDMA
	• Data transmission over long distances
	Distance in meters
	• Auto ACK-Time Adjustment
	Statistics
	• Wireless LAN and Ethernet
	Link Test
	• Checking the Wireless Connection
	Configuring and Managing
	• Management of Web-based (Secure SSL)
	• Command line interface (SSH or RS-232 (9600))
	• Utility on Windows
	• SNMPv2
	Software Update
	• Management through Web / Windows
	Physical parameters / Interfaces
	• Ethernet
	• 10/100 BaseT x 1 supports auto-negotiation, auto-negotiation
	RS-232 (COM)
	• RS-232 (UART) in RJ-45 Form Factor (for debugging)
	Audible alarm
	• Time Signal
	Reset Pin
	• COM Port (2 Pin)
	Performance of the antenna
	Type of antenna
	• Internal directional antenna with high gain
	• External directional antenna with high gain
	Gain
	• 23dBi
	Frequency range
	• 5400 ~ 5850 MHz
	HPBW (Horizontal)
	• 10° HPBW
	(Vertical)
	• 10°
