Kiirotsing
Toote omadused:
Traadita pääsupunkt 802.11n,kuni 300 Mbit/s
EOL EOS
Põhiomadused:
System
• Wireless Interface: 802.11b/g/n 2,4 GHz 2x2 MIMO
• Interface LAN: 10/10/100 Gigabit Ethernet
• Antenna: Internal antenna 4
• Antenna Gain: 4,7 dBi
• Supply: IEEE 802.3af Power Over Ethernet or external power adapter
Frequency
• 2.4 GHz - 2.497 GHz
Data transfer rate
• 802.11n:
  6.5 Mbit / s - 130 Mbit / s (20 MHz)
  6.5 MHz - 300 Mbit / s (40 MHz)
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
Transmitter output power
• 802.11b:
 21 dBm at 1, 2, 5.5, 11 Mbit / s
• 802.11g:
  21 dBm at 6 Mbit / s ~ 24 Mbit / s
  19 dBm at 36 dBm at Mbit/s18 48 Mbit / s
  17 dBm at 54 Mbit / s
• 802.11n (2,4 GGts/HT-20):
  20 dBm at MCS0 / 8
  20 dBm at MCS1 / 9
  20 dBm at MCS2/10
  20 dBm at MCS3/11
  19 dBm at MCS4/12
  18 dBm at MCS5/13
  17 dBm at MCS6/14
  16 dBm at MCS7/15
• 802.11n (2,4 GGts/HT-40)
  19 dBm at MCS0 / 8
  19 dBm at MCS1 / 9
  19 dBm at MCS2/10
  19 dBm at MCS3/11
  17 dBm at MCS4/12
  16 dBm at MCS5/13
  14 dBm at MCS6/14
  14 dBm at MCS7/15
Receiver Sensitivity
• 802.11b:
  -89 DBm at 2 Mbit / s
  -84 DBm at 11 Mbit / s
• 802.11g:
  -85 DBm at 6 Mbit / s
  -84 DBm at 9 Mbit / s
  -84 DBm at 12 Mbit / s
  -82 DBm at 18 Mbit / s
  -78 DBm at 24 Mbit / s
  -73 DBm at 36 Mbit / s
  -70 DBm at 48 Mbit / s
  -68 DBm at 54 Mbit / s
  - 82dBm at MCS0 / 8
  - 79dBm at MCS1 / 9
  - 77dBm at MCS2/10
  - 74dBm at MCS3/11
  - 70dBm at MCS4/12
  - 66dBm at MCS5/13
  - 65dBm at MCS6/14
  - 64dBm at MCS7/15
  -79 DBm at MCS0 / 8
  -76 DBm at MCS1 / 9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -63 DBm at MCS5/13
  -62 DBm at MCS6/14
  -61 DBm at MCS7/15
Security
• SSID: 16 SSID, Station Isolation
• Safety:
  + WEP
  + Dynamic WEP
  + WPA Personal / Enterprise
  + WPA2 Personal / Enterprise
• Detection and Prevention:
  + Classification of unauthorized access points and unauthorized
• Authentication:
  + Filtering by MAC-addresses
  + 802.1x
System control
• Web-User Interface: HTTP / HTTPS
• Command line: SNMP, SSH, Telnet
Füüsilised parameetrid
Power
• Power adapter: 5V / 2,5 A
• Power over Ethernet: 48 VDC + / - 10%
Type of housing
• Plastic housing or housing class Plenum
Body size
• 203 x 203 x 48 mm
Weight
• Standard package: 550 g
• Housing class Plenum: 635 g
Operating temperature
• From 0 ˚ to 50 ˚ C
Operating humidity
• From 10% to 90% noncondensing
Security
• cUL, LVD (EN60950-1), UL2043 (only for the class «plenum»)
Certificates of EMI / EMC / RF
• FCC Class B, CE Class B, C-tick, IC, VCCI, NCC, TELEC, Wi-Fi ®
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
