Kiirotsing
Toote omadused:
Wireless 802.11n High Gain USB Adapter
EOL
Kirjeldus:
DWA-137 wireless USB adapter allows you to connect your computer to a high-speed wireless networks and provides excellent reception. When the connection is established, you can access high speed Internet connection and start viewing Web-pages, streaming video and music, as well as play online games and share common access to the content for friends.
High performance
DWA-137 delivers high performance wireless connectivity for your computer. Users can easily add a network adapter and view Web-page, provide shared access to files and printers, and chat. High speed wireless connectivity extends the use of the Internet, ensuring efficient bandwidth intensive services, such as IP-telephony, online gaming, and video streaming.
Extended range
DWA-137 provides the ability to use wireless connectivity in remote places. High gain antenna, which is equipped with an adapter, improves the quality of signal reception. Therefore, using DWA-137 can connect to a wireless network at greater distances from the router or access point, than a conventional wireless adapter. The possibility of rotation of the antenna allows to eliminate low-band signal and improve reception quality by means of precise adjustment of the antenna in space. Maximize wireless performance by connecting to a wireless router 802.11n, and use a network connection anywhere in your home.
Easy to install and use
D-Link Setup Wizard provides easy installation of the USB adapter.Wi-Fi Protected Setup (WPS) technology provides a secure wireless connection, without requiring user's complicated settings. Technology does not require complicated set of manually encryption codes; just click the button to connect the device to the network and configure security. Backward compatible with the 802.11g standard, DWA-137 can be used in wireless networks with legacy equipment.
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
