Toote omadused:
Traadita kontroller Uus |
Põhiomadused:
Ports
• 4 10/100/1000 RJ-45 and 4 100/1000 SFP Combo ports
USB
• 2 USB 2.0 ports
Console Port
• 1 RJ-45
Extension Slot
• 1 Hard disk driver slot
Maximum Access Points per Unit
• 64/2561 (default/upgrade)
Maximum Access Points per Cluster
• 256/10241 (default/upgrade)
Concurrent Captive Portal Authentication Users
• 3072
Model of Managed APs
• DWL-8610AP
• DWL-8600AP
• DWL-6600AP
• DWL-3600AP
• DWL-2600AP
AP Discovery & Control
• Layer-2
• Layer-3
AP Monitoring
• Managed AP
• Rogue AP
• Authentication Fail AP
• Standalone AP
Client Monitoring
• Authenticated Client
• Rogue Client
• Authentication Fail Client
• Ad-hoc Client
Centralized RF/Security Policy Management
• Supported
Fast Roaming
• Supported
Intra-controller/Inter-controller Roaming
• Supported
Intra-subnet/Inter-subnet Roaming
• Supported
Wireless Security
• WEP
• Dynamic WEP
• WPA Personal/Enterprise
• WPA2 Personal/Enterprise
Wireless Intrusion Detection & Prevention System (WIDS)
• Rogue and Valid AP Classification
• Rogue AP Mitigation
LAN Security
• 802.1x port-based access control and guest VLAN
Authentication
• Captive Portal
• MAC Authentication
VLAN Group
• Up to 255 entries
802.1q VLAN Tagging
• Supported
Subnet-based VLAN
• Supported
Port-based VLAN
• Supported
Permanent Account Authentication Method
• Local Database
• External RADIUS
• External LDAP
• External POP3
• External Windows Active Directory (wired only)
Temporary Account Authentication Method
• Local Database
Temporary Account Creation
• Single or batch account generation by system with customized active or usage expired time
Payment Gateway
• Authorize.net
• Paypal
• SecurePay
• World Pay
Web-based User Interface
• HTTP
Command Line
• Supported
SNMP
• v1, v2c, v3
Füüsilised parameetrid
Power Supply
• 100-240 V AC, 50-60 Hz Internal power supply
Max. Power Consumption
• 26.95 W
Dimensions
• 440 x 310 x 44 mm
Operating Temperature
• 0° to 40°C
Storage Temperature
• -20° to 70°C
Operating Humidity
• 5% to 95%, Non-condensing
Emission (EMI)
• FCC Class A, CE Class A, C-Tick, IC
Safety
• cUL, LVD (EN60950-1)
Vaadake samuti
