Kiirotsing
Toote omadused:
AC1900 Wi-Fi USB 3.0 Adapter
EOL
Põhiomadused:
Features
Interfaces
• Micro-USB 3.0 port
• LED On/Off Button
• WPS button
Security
• Wi-Fi Protected Access (WPA™ & WPA2™)
• Wi-Fi Protected Setup (PBC)
Standards
• IEEE 802.11ac
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
Antenna Type
• Integrated antenna
LED
• Status
Operating System
• Windows 8.1/8/7
Interface
• Available USB port**
Physical Parameters
Dimensions
• 79.92 x 79.92 x 77 mm
Weight
• 167 grams ± 10%
Power
• Operating Voltage: 5.0 V DC ±10%
• Current Consumption: 880 mA
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 75°C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• FCC Class B
• IC
• CE
• Wi-Fi Certified
• RoHS
• RCM
* Maximum wireless signal rate derived from draft IEEE 802.11ac specification and IEEE Standard 802.11n specification. D-Link makes no warranties as to forward compatibility with future standards or compatibility with draft 802.11ac devices from other manufacturers. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors may adversely affect wireless signal range.
** Using a USB 1.1 or USB 2.0 port will affect device performance. USB 3.0 port recommended.
All references to speed and range, including the performance chart, are for comparison purposes only. Product specifications, size, and shape are subject to change without notice, and actual product appearance may differ from that depicted on the package. See inside package for warranty details
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
