Kiirotsing
Toote omadused:
Dual-Band 802.11n Unified Wireless Access Point
Projektideks
Põhiomadused:
Interfaces
• 802.11a/b/g/n
• Two 10/100 LAN ports (PoE in from either LAN1 or LAN2)
• Factory reset button
Antenna
• 5 Ghz: Two integrated 8 dBi directional antennas
• 2.4 GHz: Two integrated 3 dBi omnidirectional antennas
Power Method
• Powered by PoE only (from either LAN1 or LAN2, non-standard PoE 24 V / 1 A)
Operating Channel
• 2.4 / 5 GHz
• 11 channels for United States
• 13 channels for Europe
• 13 channels for Japan
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n: 6.5 ~ 300 Mbit/s (MCS0 ~ MCS15)*
Transmitter Output Power
• IEEE 802.11a:
  20 dBm at 6~18 Mbit/s
  19 dBm at 24 Mbit/s
  18 dBm at 36 Mbit/s
  17 dBm at 48 Mbit/s
  15 dBm at 54 Mbit/s
• IEEE 802.11b:
  20 dBm at 1 Mbit/s
  19 dBm at 2 Mbit/s
  17 dBm at 5.5 and 11 Mbit/s
• IEEE 802.11g:
  19 dBm at 24 Mbit/s
  18 dBm at 36 Mbit/s
  17 dBm at 48 Mbit/s
  15 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4 GHZ/HT-20:
  20 dBm at MCS0-MCS3, MCS8-MCS11
  19 dBm at MCS4, MCS12
  18 dBm at MCS5, MCS13
  17 dBm at MCS6, MCS14
  16 dBm at MCS7, MCS15
  2.4 GHZ/HT-40:
  19 dBm at MCS0-MCS3, MCS8-MCS11
  17 dBm at MCS4, MCS12
  16 dBm at MCS5, MCS13
  14 dBm at MCS6-MCS7, MCS14-MCS15
  5 GHz/HT-20:
  11±2 dBm at MCS0-MCS3, MCS8-MCS11
  10±2 dBm at MCS4-MCS5, MCS12-MCS-13
  9±2 dBm at MCS6-MCS7, MCS14-MCS15
  5 GHz/HT-40:
Receiver Sensitivity
• IEEE 802.11a:
  -85 dBm at 6 Mbit/s
  -84 dBm at 9 and 12 Mbit/s
  -82 dBm at 18 Mbit/s
  -78 dBm at 24 Mbit/s
  -73 dBm at 36 Mbit/s
  -70 dBm at 48 Mbit/s
  -68 dBm at 54 Mbit/s
• IEEE 802.11b:
  -89 dBm at 1 и 2 Mbit/s
  -84 dBm at 5.5 and 11 Mbit/s
• IEEE 802.11g:
  -85 dBm at 6 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -66 dBm at MCS5/13
  -65 dBm at MCS6/14
  -64 dBm at MCS7/15
  2.4 GHz/HT-40:
  -79 dBm at MCS0/8
  -76 dBm at MCS1/9
  -74 dBm at MCS2/10
  -71 dBm at MCS3/11
  -67 dBm at MCS4/12
  -63 dBm at MCS5/13
  -62 dBm at MCS6/14
  -61 dBm at MCS7/15
  5 GHz/HT-20:
  -82±2 dBm at MCS0/8
  -79±2 dBm at MCS1/9
  -77±2 dBm at MCS2/10
  -74±2 dBm at MCS3/11
  -70±2 dBm at MCS4/12
  -66±2 dBm at MCS5/13
  -65±2 dBm at MCS6/14
  -64±2 dBm at MCS7/15
  5 GHz/HT-40:
  -79±2 dBm at MCS0/8
  -76±2 dBm at MCS1/9
  -74±2 dBm at MCS2/10
  -71±2 dBm at MCS3/11
  -67±2 dBm at MCS4/12
  -64±2 dBm at MCS5/13
  -63±2 dBm at MCS6/14
  -62±2 dBm at MCS7/15
Web-based User Interface
• HTTP / HTTPS
Command Line
• SSH
SSID Security
• Up to 8 SSIDs, 4 per radio
• 802.1Q VLAN
• Station Isolation
Wireless Security
• WPA2 Personal/ Enterprise
• AES and TKIP
Authentication
• MAC Address Filtering
Physical Parameters
Dimensions
• 280 x 115 x 50 mm
Weight
• 495 grams
Power Adapter (PoE injector)
• Input: 100 to 240 V AC
• Output: 24 V DC, 1 A
Power over Ethernet
• 10 / 100 Mbps PoE (from either LAN1 or LAN2, non-standard PoE 24 V / 1 A)
Enclosure
• Plastic housing
Temperature
• Operating: -30 to 50°C
• Storage: -30 to 65°C
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• IP-55 rated
• ESD protection: 4 KV
• Surge protection: 6 KV
• CE
• EN 301 893 V1.7.1 (2012-06) (DFS/TPC)
• EN 300 328 V1.8.1 (2012-06)
• FCC
• IC
• cUL
• LVD
• C-Tick
• NCC
• Wi-Fi
• TELEC
* Maximum wireless signal rate derived from IEEE Standard 802.11g, and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
