Kiirotsing
Toote omadused:
AirPremier N PoE Access Point with Plenum-rated Chassis
Põhiomadused:
Processor
• Atheros QCA9557 (720 MHz)
RAM
• DDR2 SDRAM 64 MB
Flash
• SPI Flash 16 MB
Device Interfaces
• 802.11b/g/n wireless
• 10/100/1000BaseT PoE (802.3af) LAN port
• Power DC input
Buttons
• Reset button
LEDs
• Power
• LAN
• 2.4 GHz
Antenna
• Two detachable dipole antennas with 5 dBi @ 2.4 GHz gain
Enclosure
• Metal Plenum-rated chassis
Wireless Frequency
• 2.4 GHz to 2.4835 GHz
Standards
• IEEE 802.11b/g/n
• IEEE 802.3i
• IEEE 802.3u
• IEEE 802.3ab
• IEEE 802.3x
• IEEE 802.3az
• IEEE 802.3af
Operation Modes
• AP
• WDS
• WDS with AP
• Wireless Client
Network Management
• Web Browser Interface
• HTTP, Secure HTTP (HTTPS)
• Telnet, Secure Shell (SSH)
• D-Link Central Wi-Fi Manager
• SNMP v1, v2c and v3
• Traffic Control
• AP Array Security
Security
• WPA-Personal/Enterprise
• WPA2-Personal/Enterprise
• WEP 64/128 bit Encryption
• 802.1x
• AES and TKIP
• SSID Broadcast Disable
• MAC Address Control
• Network Access Protection
• Embedded RADIUS server
SSID/VLAN
• Support for up to 8 SSIDs/VLANs
Quality of Service (QoS)
• 4 Priority Queues
• WMM Wireless Priority
Wireless speed*
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n (2.4 GHz): 6.5 ~ 300 Mbit/s
Transmitter Output Power**
• IEEE 802.11b:
  23 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  23 dBm at 6~24 Mbit/s
  22 dBm at 36 Mbit/s
  21 dBm at 48 Mbit/s
  20 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4 GHZ/HT-20:
  23 dBm at MCS0-MCS4, MCS8-MCS12
  22 dBm at MCS5, MCS13
  21 dBm at MCS6, MCS14
  20 dBm at MCS7, MCS15
  2.4 GHZ/HT-40:
Receiver Sensitivity
• IEEE 802.11b:
  -89 dBm at 1 Mbit/s
  -87 dBm at 2 Mbit/s
  -83 dBm at 5.5 Mbit/s
  -81 dBm at 11 Mbit/s
• IEEE 802.11g:
  -84 dBm at 6 Mbit/s
  -83 dBm at 9 Mbit/s
  -81 dBm at 12 Mbit/s
  -79 dBm at 18 Mbit/s
  -76 dBm at 24 Mbit/s
  -73 dBm at 36 Mbit/s
  -70 dBm at 48 Mbit/s
  -69 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  -86 dBm at MCS0/8
  -82 dBm at MCS1/9
  -80 dBm at MCS2/10
  -77 dBm at MCS3/11
  -73 dBm at MCS4/12
  -70 dBm at MCS5/13
  -68 dBm at MCS6/14
  -67 dBm at MCS7/15
  2.4 GHz/HT-40:
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -67 dBm at MCS5/13
  -65 dBm at MCS6/14
  -64 dBm at MCS7/15
Physical Parameters
Dimensions
• 166 x 188 x 36 mm
Weight
• 689 grams
Power Input
• Power adapter (output: 12 VDC, 1 A)
• 802.3af PoE compliant
Maximum Power Consumption
• 7.9 W (PoE on)
• 6.5 W (PoE off)
Temperature
• Operating: 0 to 40°C
• Storage: -20 to 65°C
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• FCC Class B
• UL 2043
• IC
• WiFi®
* Maximum wireless signal rate derived from IEEE Standard 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
** Maximum power output varies in each country depending on local power regulations.
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
