Kirjeldus
BASIC WIRELESS CONNECTIVITY
Connect to your wireless network from your notebook PC using the DWA-610 Wireless G Notebook Adapter and browse the web, check e-mail, and chat with friends and family online. The Wireless G Notebook Adapter offers simple network connectivity without the hassle of running a network cable.
BASIC SECURITY PROTECTION
To protect your data and privacy, the Wireless G Notebook Adapter supports WEP and WPA encryption for connecting to a secure wireless network.
COMPATIBILITY ASSURANCE
The Wireless G Notebook Adapter is based on the 802.11g standard and is backwards compatible with 802.11b, ensuring compatibility with a wide range of wireless routers and networks.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup for this notebook adapter. The addition of the Wi-Fi Protected Setup (WPS) function provides advanced security features that remain simple enough for the average user to confgure correctly. This function allows for devices to undergo an easy one-time click-button confguration for establishing connection with an access point or wireless router without the need of manually setting up complex encryption codes.
Põhiomadused
Nõuded süsteemile
Standardid
Liides
32-bitine PCMCIA siin
Sagedusdiapasoon
2412 – 2472 МHz
Modulatsiooni skeemid
Andmeedastuskiirus1
Vastuvõtja tundlikkus (802.11b, PER 8%)
Vastuvõtja tundlikkus (802.11g, PER 10%)
Saatja väljundvõimsus (802.11b, toatemperatuuril 25 С)
11, 5.5, 2 ja 1 Мbit/s: 16 dBm (+/- 2dBm)
Saatja väljundvõimsus (802.11g, toatemperatuuril 25 С)
54, 48, 36, 24, 18, 12, 9, 6 Мbit/s: 12dBm (+/- 2dBm)
Antenn
Sisseehitatud antenn
Turvalisus
QoS
Toetatavad operatsioonisüsteemid
Windows 98 SE, ME, 2000, XP, Vista
Sertifikaadid
Sidustooted
DWA-610 Juhtmavaba PCMCIA-adapter 802.11g, kuni 54 Мbit/s
