DAP-1150EOL EOS
Juhtmavaba pääsupunkt 802.11g, kuni 54 Мbit/s
Kust osta
Kirjeldus
CONNECT HOME USERS TO A WIRELSS NETWORK
Create a wireless network for your home using the D-link DAP-1150, Connect this 802.11g standard Wireless Access point a broadband modem and wirelessly share your internet connection. enjoy surfng the web, checking e-mail, and chatting with family and friends online.
PROTRECT WIRELESS NETWORK AND DATA
The DAP-1150 provides 64/128-bit Wep encryption and WpA/WPA2 security to protect your network and wireless data. in addition, it also provides MAC address fltering and the Disable SSiD broadcast function to limit outsiders’ access to your wireless network.
FLEXIBlY CONFIGURE YOUR AP FOR DIFFERENT APPLICATIONS
The DAP-1150 can be confgured to operate as an Access point to act as a central hub for wireless users, a Wireless Client to connect to a game console, or a Repeater to extend the wireless coverage to cover “dead” spots. these fexible operations allow you to use your DAP-1150 for different purposes.
EASY TO INSTALL AND USE
With D-link Setup Wizard, you can set up your wireless network in minutes. it confgures your DAp-1150, makes it easy to add new wireless devices onto the network, and helps you create a simple wireless network for your home. A slide switch is provided on the back for users to select an operation mode. in addition, the DAP-1150 is Wi-Fi protected Setup™ (WpS) certifed, making it even easier to confgure your wireless network and enable security
Põhiomadused
Standardid
  • 802.11g
  • 802.11b
  • 802.3/802.3u 10Base-T/100Base-TX Ethernet
  • ANSI/IEEE 802.3 NWay auto-negotiation
    Liidesed
  • 802.11g juhtmevaba LAN
  • 1 x 10/100Base-TX Ethernet LAN port
    Sagedusdiapasoon
    2,4 – 2,4835 GHz
    Kanalite arv
  • FCC: 11
  • ETSI: 13
    Modulatsiooni skeemid
  • 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
    Töörežiimid
  • Pääsupunkt
  • Juhtmevaba klient
  • Repiiter
    Antenn
    Eemaldatav suundantenn võimendusteguriga 2dBi (RP-SMA ühenduspesa)
    Andmeedastuskiirus
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Мbit/s
  • 802.11b: 1, 2, 5.5, 11 Мbit/s
    Vastuvõtja tundlikkus
    (802.11b, PER 8%)
  • 11 Мbit/s: -80 dBm
  • 5,5 Мbit/s: -84 dBm
  • 2 Мbit/s: -87 dBm
  • 1 Мbit/s: -88 dBm
    (802.11g, PER 10%)
  • 54 Мbit/s: -65 dBm
  • 48 Мbit/s: -66 dBm
  • 36 Мbit/s: -70 dBm
  • 24 Мbit/s: -74 dBm
  • 18 Мbit/s: -77 dBm
  • 12 Мbit/s: -79 dBm
  • 9 Мbit/s: -81 dBm
  • 6 Мbit/s: -82 dBm
    Saatja väljundvõimsus
    (802.11b, temperatuuril 25 С)
    11, 5.5, 2 ja 1 Мbit/s: 16 dBm (tüüpiline)
    (802.11g, emperatuuril 25 С)
    54, 48, 36, 24, 18, 12, 9, 6 Мbit/s: 14 dBm
    Turvalisus
  • 64/128-bitine WEP-andmekrüpteerimine
  • Wi-Fi Protected Access (WPA/ WPA2-PSK, WPA/WPA2-EAP)
  • TKIP, AES
  • МАС-aadressite filtreerimine
  • SSID broadcast väljalülitamise võimalus
    QUALITY OF SERVICE (QoS)
    Wi-Fi Multimedia (WMM)
    Seadme juhtimine
  • Veebiliidese baasil: Internet Explorer v.6 või uuem, Netscape Navigator v.6 või uuem või muu veebibrauser Java toetusega.
  • WPS järgmiste töörežiimide toetusega: pääsupunkt, juhtmevaba klient ja repiiter
  • Füüsilised parameetrid
    Indikaatorid
  • Power
  • WLAN
  • LAN
    Toide sisendil
    5 V alalisvool 2 А, väline toiteadapter
    Mõõdud
    144 x 109 x 30 mm
    Kaal
    220 g
    MTBF
    >30 000 t
    Töötemperatuur
    0˚ kuni 55˚C
    Säilitamistemperatuur
    -10˚ kuni 70˚C
    Tööniiskus
    10% kuni 90%, ilma kondensatsioonita
    Säilitamisniiskus
    5% kuni 95%, ilma kondensatsioonita
    Sertifikaadid
  • FCC Class B
  • CE
  • C-Tick
  • Wi-Fi
  • Sertifikaadid
    Sidustooted
    Pildid
    DAP-1150
    Tagantvaade
    Eestvaade
    Failid
    Vaadake samuti
