DAP-1150EOL EOS
Kirjeldus
CONNECT HOME USERS TO A WIRELSS NETWORK
Create a wireless network for your home using the D-link DAP-1150, Connect this 802.11g standard Wireless Access point a broadband modem and wirelessly share your internet connection. enjoy surfng the web, checking e-mail, and chatting with family and friends online.
PROTRECT WIRELESS NETWORK AND DATA
The DAP-1150 provides 64/128-bit Wep encryption and WpA/WPA2 security to protect your network and wireless data. in addition, it also provides MAC address fltering and the Disable SSiD broadcast function to limit outsiders’ access to your wireless network.
FLEXIBlY CONFIGURE YOUR AP FOR DIFFERENT APPLICATIONS
The DAP-1150 can be confgured to operate as an Access point to act as a central hub for wireless users, a Wireless Client to connect to a game console, or a Repeater to extend the wireless coverage to cover “dead” spots. these fexible operations allow you to use your DAP-1150 for different purposes.
EASY TO INSTALL AND USE
With D-link Setup Wizard, you can set up your wireless network in minutes. it confgures your DAp-1150, makes it easy to add new wireless devices onto the network, and helps you create a simple wireless network for your home. A slide switch is provided on the back for users to select an operation mode. in addition, the DAP-1150 is Wi-Fi protected Setup™ (WpS) certifed, making it even easier to confgure your wireless network and enable security
Põhiomadused
Standardid
Liidesed
Sagedusdiapasoon
2,4 – 2,4835 GHz
Kanalite arv
Modulatsiooni skeemid
Töörežiimid
Antenn
Eemaldatav suundantenn võimendusteguriga 2dBi (RP-SMA ühenduspesa)
Andmeedastuskiirus
Vastuvõtja tundlikkus
(802.11b, PER 8%)
(802.11g, PER 10%)
Saatja väljundvõimsus
(802.11b, temperatuuril 25 С)
11, 5.5, 2 ja 1 Мbit/s: 16 dBm (tüüpiline)
(802.11g, emperatuuril 25 С)
54, 48, 36, 24, 18, 12, 9, 6 Мbit/s: 14 dBm
Turvalisus
QUALITY OF SERVICE (QoS)
Wi-Fi Multimedia (WMM)
Seadme juhtimine
