Kiirotsing
Toote omadused:
External power supply for DAS-4192, 321.6W
Põhiomadused:
Built-in protective mechanisms
• Overload protection is triggered when the output power exceeds the nominal value of 5%-35%
• Protection against the output voltage exceedance and short-circuit is triggered when the output voltage is from 57.6V to 67.2
• Protection against high temperatures
Ventilation
• Built-in DC fan
• Fan speed control
Füüsilised parameetrid
Input voltage range
• 88 to 264VAC
• 124 to 370VDC
Range of the input AC voltage
• 47Hz to 63Hz
Leakage
• <1.0mA at 240VAC
Output voltage
• 48V
Nominal output current
• 6.7A
Range of output current
• From 0 to 6.7A
Rated power output
• 321.6 W
Dimensions
• 215 x 115 x 50mm
Temperature
• Operating: -20° to 65°C
• Storage: -40° to 85°C
Humidity
• Operating: 20% to 90% non-condensing
• Storage: 10% to 95% non-condensing
MTBF
• 207,000 hours at rated voltage lines, maximum load, ambient temperature of 25°C
Safety
• UL
• TUV
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
