Kiirotsing
Toote omadused:
Wireless N150 ADSL2+ Modem Router
Põhiomadused:
Hardware
Interfaces
• ADSL: 1 RJ-11 port
• LAN: 4 RJ-45 10/100BASE-TX Fast Ethernet ports with auto MDI/MDIX
• WLAN: built-in 802.11b, g and n wireless interface
Frequency range
• 2412~2484MHz
Wireless data rate
• 802.11b: 11, 5.5, 2, 1Mbps
• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6Mbps
• 802.11n
  HT20: 150, 130, 117, 104, 78, 52, 39, 26, 13Mbps
  HT40: 150, 130, 117, 104, 78, 52, 39, 26, 13Mbps
Transmitter output power
The maximum value of the transmitter power will vary in accordance with the rules of the radio-frequency regulation in your country
• 802.11b: 16.5~18.5dBm
• 802.11g: 13.5~16.5dBm
• 802.11n: 13.5~16.5dBm
Modulation Schemes
• 802.11b: CCK (11, 5.5Mbps), DQPSK (2Mbps), DBPSK (1Mbps), DSSS
• 802.11g: PSK/CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK 16QAM, 64QAM
• 802.11n: PSK/CCK, DBPSK, DQPSK, OFDM, etc.
ADSL Standards
• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU T G.994.1 (G. hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
• ADSL2+: ITU-T G.992.5 Annex A/L/M
Software
WAN connection types
• ADSL:
  PPPoE
  PPPoA
  IPoA
  Static IP
  Dynamic IP
  Bridge
• Ethernet:
  PPPoE
  Static IP
  Dynamic IP
  Bridge
Wireless network
• IEEE 802.11n standard, IEEE 802.11b/g compliant
• WEP data encryption
• WPA/WPA2 security supporting TKIP, AES and TKIP+AES
• MAC-based access to wireless network
• PBC method of WPS
• Managing connected stations
• Advanced Settings
ATM/PPP protocols
• Bridged and routed Ethernet encapsulation
• VC/LLC-based multiplexing
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
• ATM Adaptation Layer Type 5 (AAL5)
• ITU-T I.610 OAM F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2364)
• PPP over Ethernet (PPPoE)
• Keep-alive for PPP connections
Network protocols and functions
• DHCP server/client/relay
• DNS relay
• Dynamic DNS
• Static IP routing
• Remote access
• Network statistics for each interface
• IGMP proxy
• IGMP snooping
• RIP
• UPnP
• VLAN support
• WAN ping respond
• Supports SIP
• Supports RTSP
Firewall and access control
• IP filters
• MAC filter
• URL Filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
QoS
• Interface grouping
• VLAN priority (802.1p)
Configuration and management
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Automatic notification of new firmware version
• Support of remote logging
• Automatic synchronization of system time with NTP server and manual date/time setup
• Ping function
Füüsilised parameetrid
LEDs
• POWER
• DSL
• INTERNET
• WLAN
• LAN 1-4
• WPS
• USB
Power
• External power adapter 12VDC/0.5A
Buttons
• ON/OFF power switch
• RESET button to restore factory defaults
• WPS/WLAN button
Operating temperature
• 0 to 40°C
Storage temperature
• -20 to 70°C
Humidity
• 5% to 95% non-condensing
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
