DSL-2640U/RB/U1EOL EOS
Wireless ADSL2+ (Annex B) Router with Ethernet WAN Support
Kirjeldus
ADSL Port and 4-port Switch
The router is equipped with an ADSL port to connect to an ADSL line. The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network. In addition, any Ethernet port of the device can be used to connect to a private Ethernet line.
Wireless Interface
You are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n.
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, and the WPS function.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Security
The wireless router DSL-2640U includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of the wireless router DSL-2640U via the user-friendly web-based interface (the interface is available in several languages).
Now you can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
Põhiomadused
				 Software
				 WAN connection types
				 • PPPoA
				• PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• IPoA
				• Static IP / Dynamic IP
				• Static IPv6 / Dynamic IPv6
				• Bridge
				 Network functions
				 • DHCP server/relay
				• DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation
				• DNS relay
				• Support of DNSv6 AAAA records
				• Dynamic DNS
				• Static IP routing
				• Static IPv6 routing
				• IGMP Proxy
				• IGMP snooping
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP
				• Support of RTSP
				 Firewall functions
				• IP filters
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in Yandex.DNS web content filtering service
				 VPN
				 • PPTP/L2TP/PPPoE pass-through
				 QoS
				 • Interface grouping
				• VLAN priority (802.1p)
				 Management
				 • Local and remote access to settings through TELNET/WEB (HTTP)
				• Multilingual web-based interface for configuration and management
				• Support of remote logging
				• Ping function
				• TR-069 client
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11b/g/n
				 Frequency range
				 • 2400 ~ 2483.5MHz
				 Wireless connection security
				 • WEP
				• WPA/WPA2 (Personal)
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Managing connected stations
				• Advanced settings
				 Wireless connection rate
				 • IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n: from 6.5 to 150Mbps (from MCS0 to MCS7)
				 Transmitter output power
				 • 802.11b
				16.5 ~ 18.5dBm
				• 802.11g
				13.5 ~ 16.5dBm
				• 802.11n
				13.5 ~ 16.5dBm
				 Modulation schemes
				 • 802.11b: CCK (11, 5.5Mbps), DQPSK (2Mbps), DBPSK (1Mbps), DSSS
				• 802.11g: PSK/CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
				• 802.11n: PSK/CCK, DBPSK, DQPSK, OFDM, etc.
				 Physical Parameters
				 Dimensions
				 • 160 x 115 x 58 mm (6.3 x 4.5 x 2.3 in)
				 Weight
				 • 210 g (0.46 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 0.5A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 65 °C
				 Humidity
				 • From 5% to 95% (non-condensing)
				 Delivery Package
				 • Router DSL-2640U
				• Power adapter DC 12V/0.5A
				• RJ-11 telephone cable
				• Straight-through Ethernet cable (CAT 5E)
				• Splitter
Sertifikaadid
Sidustooted
DSL-2640U/RB/U1   Wireless ADSL2+ (Annex B) Router with Ethernet WAN Support
