DSL-2750U/RAEOL EOS
Wireless ADSL2+ Router with 3G/LTE/Ethernet WAN Support and USB Port
Kirjeldus
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
ADSL Port and 4-port Switch, Ethernet WAN Support
The router is equipped with an ADSL port to connect to an ADSL line. The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network. In addition, any Ethernet port of the device can be used to connect to a private Ethernet line.
Wireless Interface
Using the DSL-2750Udevice, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n.
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DSL-2750Uincludes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DSL-2750Uvia the user-friendly web-based interface (the interface is available in several languages).
The fast and easy configuration wizard allows you to specify all needed parameters in several simple steps.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
Põhiomadused
				 Hardware
				 Processor
				 • RTL8676S
				 RAM
				 • 32MB, SDRAM
				 Flash
				 • 8MB, SPI
				 Interfaces
				 • RJ-11 ADSL port
				• 4 10/100BASE-TX LAN ports
				• USB 2.0 port
				 LEDs
				 • POWER
				• 4 LAN LEDs
				• WLAN
				• WPS
				• USB
				• DSL
				• INTERNET
				 Buttons
				 • ON/OFF button to power on/power off
				• RESET button to restore factory default settings
				• WPS button to set up wireless connection
				• WIRELESS ON/OFF button to enable/disable wireless network
				 Antenna
				 • Two external non-detachable omnidirectional antennas (5dBi gain)
				 MIMO
				 • 2 x 2
				 Power connector
				 • Power input connector (DC)
				 DSL Parameters
				 ADSL Standards
				 • ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
				• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
				• ADSL2+: ITU-T G.992.5 Annex A/L/M
				 ATM/PPP Protocols
				 • Bridged and routed Ethernet encapsulation
				• VC-based or LLC-based multiplexing
				• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
				• ATM Adaptation Layer Type 5 (AAL5)
				• ITU-T I.610 OAM F4/F5 loopback
				• ATM QoS
				• PPP over ATM (RFC 2364)
				• PPP over Ethernet (PPPoE)
				• Keep-alive for PPP connections
| Software | |
				 WAN connection types
				 • LTE
				• 3G
				• PPPoA
				• PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• IPoA
				• Static IPv4 / Dynamic IPv4
				• Static IPv6 / Dynamic IPv6
				• Bridge
				 Network functions
				 • DHCP server/relay
				• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				• DNS relay
				• Dynamic DNS
				• Static IP routing
				• Static IPv6 routing
				• IGMP Proxy
				• IGMP snooping
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• WAN reservation
				 Firewall functions
				• IP filter
				• IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in Yandex.DNS web content filtering service
				 VPN
				 QoS
				 • Interface grouping
				• VLAN priority (802.1p)
				 USB interface functions
				 • USB modem
				- Auto connection to available type of supported network (4G/3G/2G)
				- Auto configuration of connection upon plugging in USB modem
				- Enabling/disabling PIN code check, changing PIN code1
				• USB storage
				- File browser
				- Print server
				- Access to storage via accounts
				- Built-in Samba/FTP/DLNA server
				- Built-in Transmission torrent client; uploading/downloading files from/to USB storage
				 Management
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Multilingual web-based interface for configuration and management
				• Support of logging to remote host/connected USB storage
				• Ping utility
				• Traceroute utility
				• TR-069 client
| Wireless Module Parameters | |
				 Standards
				 • IEEE 802.11b/g/n
				 Frequency range
				 • 2400 ~ 2483.5MHz
				 Wireless connection security
				 • WEP
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Guest Wi-Fi / support of MBSSID
				• Limitation of wireless network rate
				• Periodic scan of channels, automatic switch to least loaded channel
				• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Wireless connection rate
				 • IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
				 Transmitter output power
				 • 802.11b (typical at room temperature 25 °C)
				15dBm
				• 802.11g (typical at room temperature 25 °C)
				13.5 ~ 15dBm
				• 802.11n (typical at room temperature 25 °C)
				13.5 ~ 15dBm
				 Receiver sensitivity
				-84dBm
				-72dBm
				HT20
				-70dBm
				HT40
				-67dBm
				 Modulation schemes
				 • 802.11b: CCK (11, 5.5Mbps), DQPSK (2Mbps), DBPSK (1Mbps), DSSS
				• 802.11g: PSK/CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
				• 802.11n: PSK/CCK, DBPSK, DQPSK, OFDM, etc.
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 174 x 119 x 32 mm (6.6 x 4.7 x 1.3 in)
				 Weight
				 • 197 g (0.43 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 1A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 70 °C
				 Humidity
				 • From 5% to 95% (non-condensing)
				 Delivery Package
				 • Router DSL-2750U
				• Power adapter DC 12V/1A
				• RJ-11 telephone cable
				• Ethernet cable
				• Splitter
				 Supported USB modems2
				 GSM
				 • Alcatel X500
				• D-Link DWM-152C1
				• D-Link DWM-156A6
				• D-Link DWM-156A7
				• D-Link DWM 156A8
				• D-Link DWM-156C1
				• D-Link DWM-157B1
				• D-Link DWM-157B1 (Velcom)
				• D-Link DWM-158D1
				• D-Link DWR-710
				• Huawei E150
				• Huawei E1550
				• Huawei E156G
				• Huawei E160G
				• Huawei E169G
				• Huawei E171
				• Huawei E173 (Megafon)
				• Huawei E220
				• Huawei E3131 (MTS 420S)
				• Huawei E352 (Megafon)
				• Prolink PHS600
				• Prolink PHS901
				• ZTE MF112
				• ZTE MF192
				• ZTE MF626
				• ZTE MF627
				• ZTE MF652
				• ZTE MF667
				• ZTE MF668
				• ZTE MF752
				 LTE
				 • Huawei E3131
				• Huawei E3272
				• Huawei E3351
				• Huawei E3372
				• Huawei E367
				• Huawei E392
				• Megafon M100-1
				• Megafon M100-2
				• Megafon M100-3
				• Megafon M100-4
				• Megafon M150-1
				• Megafon M150-2
				• Quanta 1K6E (Beeline 1K6E)
				• MTS 824F
				• MTS 827F
				• Yota LU-150
				• Yota WLTUBA-107
				• ZTE MF823
				• ZTE MF827
				 Smartphones in USB tethering mode
				 • Some models of Android smartphones
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Sertifikaadid
Sidustooted
DSL-2750U/RA/U3  Wireless ADSL2+ Router with 3G/LTE/Ethernet WAN Support and USB Port
