Kiirotsing
Toote omadused:
Wireless Dual Band VDSL2 Router with ASDL2+/3G/LTE Support and USB Port
Põhiomadused:
Hardware
Processor
• RTL8685PB (1GHz)
RAM
• 128MB, DDR2, built in processor
Flash
• 16MB, SPI
Interfaces
• RJ-11 DSL port
• 4 10/100/1000BASE-T LAN ports
• USB 2.0 port
LEDs
• POWER
• DSL
• INTERNET
• 4 LAN LEDs
• 2.4G WLAN
• 5G WLAN
• WPS
• USB
Buttons
• ON/OFF button to power on/power off
• RESET button to restore factory default settings
• WPS button to set up wireless connection
• WIFI button to enable/disable wireless network
Antenna
• Two external non-detachable antennas for 2.4GHz band (5dBi gain)
• Two external non-detachable antennas for 5GHz band (5dBi gain)
MIMO
• 2 x 2
Power connector
• Power input connector (DC)
DSL Parameters
VDSL/ADSL Standards
• VDSL2: ITU G.993.2, support of 8a, 8b, 8c, 8d, 12a, 12b, 17a, 30a, 35b profiles
• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
• ADSL2+: ITU-T G.992.5 Annex A/L/M
ATM/PPP Protocols
• Bridged and routed Ethernet encapsulation
• VC-based or LLC-based multiplexing
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
• ATM Adaptation Layer Type 5 (AAL5)
• ITU-T I.610 OAM F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2364)
• PPP over Ethernet (PPPoE)
• Keep-alive for PPP connections
Software
WAN connection types
• LTE / 3G
• PPPoE / IPv6 PPPoE / PPPoE Dual Stack / PPPоA
• Static IPv4 / Dynamic IPv4 / IPoA
• Static IPv6 / Dynamic IPv6
• PPTP / L2TP
• Bridge
Network functions
• Support of IEEE 802.1X for Internet connection
• DHCP server/relay
• Advanced configuration of built-in DHCP server
• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
• DNS relay
• Dynamic DNS
• Static IP routing
• Static IPv6 routing
• IGMP Proxy
• IGMP snooping
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• WAN reservation
• LAN/WAN conversion
Firewall functions
• IPv4/IPv6 filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
VPN
• IPsec tunnels
QoS
• Interface grouping
• VLAN priority (802.1p)
USB interface functions
• USB modem
  - Auto connection to available type of supported network (4G/3G/2G)
  - Auto configuration of connection upon plugging in USB modem
  - Enabling/disabling PIN code check, changing PIN code1
• USB storage
  - File browser
  - Print server
  - Access to storage via accounts
  - Built-in Samba/FTP/DLNA server
  - Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management and monitoring
• Local and remote access to settings through SSH/TELNET/WEB (HTTP/HTTPS)
• Bilingual web-based interface for configuration and management (Russian/English)
• Support of D-Link Assistant application for Android and iPhone smartphones
• Support of logging to remote host/connected USB storage
• Ping utility
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11a/n/ac
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
• 5150 ~ 5350MHz
• 5650 ~ 5850MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
• Guest Wi-Fi / support of MBSSID
• Rate limitation for wireless network
• Periodic scan of channels, automatic switch to least loaded channel
• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
• Support of 802.11ac (5GHz) TX Beamforming
Wireless connection rate
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
• IEEE 802.11ac (5GHz): from 6.5 to 867Mbps (from MCS0 to MSC9)
Transmitter output power
• 802.11a
15dBm at 6, 54Mbps
• 802.11b
15dBm at 1, 11Mbps
• 802.11g
15dBm at 6, 54Mbps
• 802.11n
HT20/HT40
15dBm at MCS0, 7
• 802.11ac
HT20
15dBm at MCS0, 8
HT40
15dBm at MCS0, 9
HT80
15dBm at MCS0, 9
Receiver sensitivity
• 802.11a
-86dBm at 6Mbps
-65dBm at 54Mbps
• 802.11b
-90dBm at 1Mbps
-76dBm at 11Mbps
• 802.11g
-86dBm at 6Mbps
-68dBm at 54Mbps
• 802.11n
2.4GHz
HT20
-85dBm at MCS0
-67dBm at MCS7
HT40
-82dBm at MCS0
-64dBm at MCS7
5GHz
HT20
-85dBm at MCS0
-65dBm at MCS7
HT40
-82dBm at MCS0
-61dBm at MCS7
• 802.11ac
HT20
-82dBm at MCS0
-59dBm at MCS8
HT40
-79dBm at MCS0
-54dBm at MCS9
HT80
-76dBm at MCS0
-51dBm at MCS9
Modulation schemes
• 802.11a: BPSK, QPSK, 16 QAM, 64 QAM with OFDM
• 802.11b: DQPSK, DBPSK, DSSS, and CCK
• 802.11g: BPSK, QPSK, 16 QAM, 64 QAM with OFDM
• 802.11n: BPSK, QPSK, 16 QAM, 64 QAM with OFDM
• 802.11ac: BPSK, QPSK, 16 QAM, 64 QAM, 256 QAM with OFDM
Physical Parameters
Dimensions (L x W x H)
• 217 x 148 x 47 mm (8.5 x 5.8 x 1.9 in)
Weight
• 345 g (0.76 lb)
Operating Environment
• Output: 12V DC, 1.5A
Temperature
• Operating: from 5 to 40 °C
• Storage: from -20 to 70 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DSL-245GR
• Power adapter DC 12V/1.5A
• RJ-11 telephone cable
• Ethernet cable
• Splitter
Supported USB modems2
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM 156A8
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• D-Link DWR-710
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E3131 (MTS 420S)
• Huawei E352 (Megafon)
• Prolink PHS600
• Prolink PHS901
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
LTE
• Alcatel IK40V
• D-Link DWM-222
• Huawei E3131
• Huawei E3272
• Huawei E3351
• Huawei E3372
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-2
• Megafon M100-3
• Megafon M100-4
• Megafon M150-1
• Megafon M150-2
• Quanta 1K6E (Beeline 1K6E)
• MTS 824F
• MTS 827F
• Yota LU-150
• Yota WLTUBA-107
• ZTE MF823
• ZTE MF827
Smartphones in USB tethering mode
• Some models of Android smartphones
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
