Kiirotsing
Toote omadused:
ADSL Router With Built-in 4-Port Switch
EOL
Kirjeldus:
Simplified, Cost-saving Broadband Internet Connection
With the DSL-504G, you can easily share your ADSL broadband line in your office or at home. To let everybody logon, this device automatically creates and assigns an IP number for each user, simplifying every one's logon operation.
Built-in ADSL Modem and Switch Ports
A standard-based ADSL modem in built into this router, making connection to the Internet a breeze. The router also incorporates a 4-port 10/100Mbps switch, providing ready connection for workstations and servers, while saving you the cost and trouble of installing a separate Ethernet switch.
Network Security
The DSL-504G provides NAT protection for your office and home users from Internet intruders and hacker attacks, plus VPN pass-through for extra security. It blocks and re-directs certain ports to limit the services that outside users can access your network. Virtual Server Mapping is used to re-task services to multiple servers. The DSL-504G can be set to allow separate FTP, Web, and Multiplayer game servers to share the same Internet-visible IP address while still protecting your servers and workstations from hackers.
DMZ Host to Open Public Domain
You can configure any of the built-in LAN switch ports to function as a DMZ port. A DMZ setting can be applied to a single client (such as a Web server) behind the router to fully expose it to the Internet and ensure complete Internet application compatibility even if the specific port is not known. This allows you to set up web sites and e-commerce business from your office while maintaining protection for the rest of your office LAN.
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
