DMC-805XEOL
Media converter with one 10GBase-CX4 port and one 10GBase-X SFP+ port
Kirjeldus
DMC-805X Media Converter converts the signal from the 10G CX4 standard to the 10G SFP+ signal. DMC-805X is equipped with a slot for SFP+ optical transceivers, user-selectable, and extends the network connection for the different distances depending on the capabilities of SFP + transceiver. DMC-805X is a high performance 10G media converter, which allows you to increase the distance for servers equipped with network cards or old CX4 10G switches with port 10G CX4.
DMC-805X can be used as a standalone unit or can be mounted in a standard rack of chassis (DMC-1000), and the control function will be available. Control Module (DMC-1002) allows users to monitor the status of DMC-805X and the chassis power in real-time mode. It also sends alarm and notifies users of emergency situations. The control module meets the following industry standards, including SNMP and HTTP, and allows users to monitor and manage the chassis from a third-party SNMP management station or through a web-browser.
Põhiomadused
Media converter characteristics
• One-channel media conversion between 10 Gbps SFP+ and 10 Gbps CX4
• Support for various distances using 802.3ae/aq compatible SFP+ transceivers
• Link pass through support
• Switch for setting of the LLR functions
• Switching mode: Store-and-forward
• Support the method of back-pressure and IEEE 802.3x flow control
• Wire-speed performance
• Status LEDs on the front panel
• Use as a single unit or installation in the chassis (DMC-1000)
• Easy management via web-interface*
• Graphical User Interface (GUI)*
Physical Parameters
LEDs
• Power, Link/Act/Speed
Power Input
• 3.4 watts of AC power
Maximum power consumption
Power on (Standby mode)
• Input power: 1.63 W DC 2.26 W AC
Dimensions
• 120 x 88 x 25 mm
Weight
• 0.29 kg
Operating temperature
• 0° to 40°C
Storage temperature
• -10° to 70°C
Operating Humidity
• From 10% to 90% non-condensing
EMI
• CE Class A, LVD
* Only through DMC-1000 chassis
Sertifikaadid
Sidustooted
DMC-805X   Media converter with one 10GBase-CX4 port and one 10GBase-X SFP+ port
Pildid
DMC-805X/A1
Tagantvaade
Eestvaade
Eestvaade
Failid
Vaadake samuti
