DMC-F15SCEOL EOS
10/100BASE-TX to 100BASE-FX SC Single-mode Media Converter (15 km)
Kirjeldus
	D-Link’s Standalone Media Converters turn an Ethernet connection into fiber, allowing for ultra-fast long distance connections. Installation of a Standalone Media Converter is simple, and allows you to tap into fiber speeds with ease. Instead of requiring an investment in an entire chassis, the standalone series is able to provide the same high-quality conversion on a unit-by-unit basis. The standalone nature of these means that you can use save space and cut costs while still extending your network over long distances up to 60 km on a fiber-optic line. In addition to all models supporting 10/100 Mbps Half/Full-duplex, the DMC-G01LC also allows for 1000 Mbps Full-Duplexing, letting you truly maximize your network’s potential.
	Extend Your Network
	Fiber-optic speeds are critical to success, but twisted-pair cabling can only go so far. Using D-Link’s converters you can change a twisted-pair Fast Ethernet connection into a single-mode or multi-mode fiber connection that can go much farther. Converters for distances of anywhere from 2 km to 60 km allow you to optimize your selection.
	No Wasted Space
	Its compact size fits anywhere and doesn’t require an entire rack. Measuring just 70 mm wide by 95 mm long by 25 mm high, the total volume of one unit is just 0.166 liters. This allows for convenient installation wherever it is needed, especially in limited space environments such as telecommunication cabinets or a distribution box.
	Plug & Play
	The media converters offered by D-Link include several industry-standard technologies that make them easy to operate, like 802.3u/x/ab*. Auto-MDI/MDIX and Auto-Negotiation make sure your cable connection functions at the highest possible speed while remaining compatible. There’s no management software to configure – simply connect the converter.
Põhiomadused
	Max. Forwarding Rate
	• 10 M: 14, 880 pps
	• 100 M: 148,800 pps
	Forwarding mode
	• Cut-Through
	Packet Buffer Memory
	• 128 Kbits
	Switching Capacity
	• 2 Gbps
	LAN
	• 1 x 10/100 Mbps port
	• IEEE 802.3u
	• IEEE 802.3x
	• Auto-Negotiation for each port
	• Half/Full-Duplex operation at 10/100 Mbps
	• Back pressure at Half-Duplex operation
	• Auto MDI/MDIX
	• Wire speed reception and transmission
	Physical Parameters
	External Power Adapter
	• Switching 5V/1A Level V Power Adapter, ErP compliant
	Power Consumption (Max.) at 240 V
	• DC 1.45 W
	• AC 2.21 W
	Power Consumption (Standby) at 240 V
	• DC 1.00 W
	• AC 1.61 W
	Heat Dissipation (Max.)
	• 7.54 BTU/h
	MTBF (hours)
	• 482,583
	Operation Temperature
	• 0° to 50°C
	Storage Temperature
	• -10° to 70°C
	Operating Humidity
	• 10 to 90%
	Storage Humidity
	• 5 to 90%
	EMI
	• EMI: CE class A, FCC class A, VCCI class A, BSMI class A
	Safety
	• LVD, UL/cUL
	* DMC-G01LC only
Sertifikaadid
Sidustooted
DMC-F15SC 10/100BASE-TX to 100BASE-FX SC Single-mode Media Converter (15 km)
