DMC-805G
Kirjeldus
This converter converts 1000BASE-T twisted-pair signals to 1000BASE-SX/LX multi-mode/single-mode fiber signals. Maximum fiber cable distance is 550 m for 1000BASE-SX * and 20 km for 1000BASE-LX. 1 RJ-45 twisted-pair port and 1 SFP port (mini GBIC) are provided.
* Maximum fiber cable distance support is as follows:
- For 62.5/125 micron multi-mode fiber cable: up to 220 m
- For 50/125-micron multi-mode fiber cable: up to 550 m
Põhiomadused
	Interface
	Number of Ports
	• 1 x 1000BASE-T RJ-45 port
	• 1 x 1000BASE-SX/LX SC port
	Standards
	• IEEE 802.3ab for 1000BASE-TX
	• IEEE 802.3z for 1000BASE-SX/LX
	Data Transfer Rate
	• 2000 Mbps (full-duplex)
	Duplex Mode
	• Full-duplex
	Media Types
	• 1000BASE-T: 4-pair Cat. 5, Shielded Twisted Pair (STP) (up to 100 m)
	•  1000BASE-SX/LX: Depends on transceiver
	Media Exchange Interface
	• Auto-MDI/MDIX
	Functionality
	Transmission Mode
	• Store-and-forward
	Forwarding Rate
	• Full wire-speed forwarding rate
	Management
	• Through the DMC-1000 chassis with the DMC-1002 management module installed
	Management Functions
	• LLR
	• Fiber mode
	Physical
	Diagnostic LEDs
	• Power
	• LINK/ACT (for twisted pair ports)
	AC Input
	• 5 V/1 A external power adapter
	Temperature
	• Operating: 0 °C to 40 °C (32 °F to 104 °F)
	• Storage: -25 °C to 70 °C (13 ºF to 158 °F)
	Humidity
	• 10% to 90% RH, non-condensing
	Dimensions
	• 120 x 88 x 25 mm (4.72 x 3.46 x 0.98 in)
	Weight
	• 305 g (0.67 lbs)
	Fiber Wavelength
	• 1300 nm
	Supported Fiber Cable Length
	• Depends on SFP transceiver
	Emission Certifications (EMI)
	• FCC Class A
	• VCCI Class A
	• CE Class A
Sertifikaadid
Sidustooted
DMC-805G 1000BASE-T Twisted Pair to 1000BASE-SX/LX Single-mode fiber (variable, LC) Media Converter Module
