DXE-810TEOL
PCI Express Adapter with 1 10GBase-T Port
Kust osta
Kirjeldus
The D-Link DXE-810T PCI Express 10 Gigabit Ethernet Adapter is a high performance adapter designed for the high-speed PCI Express bus architecture. The PCI Express 10 Gigabit Ethernet Adapter offers increased bandwidth, reliability, and more functionality than standard PCI network cards. It is specifically designed to allow throughput at rates up to 20 Gbps, eliminating the bottleneck that exists with current 32 and 64-bit PCI bus architectures.
Advanced Features and Security
This adapter supports 802.1Q VLAN standard, allowing you to organize an operation with tagged traffic. With support for advanced features such as 802.3x Flow Control, Jumbo Frames, and SNMP for network management, the DXE-810T can easily interoperate with your current networking equipment.
Checksum Offloading
The DXE-810T features TCP, UDP, and IP checksum off-loading functionality, which transfers the checksum processing tasks from the computer’s CPU to the network card. The DXE-810T’s ability to handle the checksum processing means that the CPU’s processing power can be used for other tasks while still achieving 10 Gbps network speeds.
Põhiomadused
Interface
• Single Port 10GBASE-T RJ-45
Standards
• IEEE 802.1Q VLAN tagging
• IEEE 802.3x flow control
• PCI Express x4 2.0, 5 GT/s compliant
• IEEE 802.3an 10GBASE-T
• IEEE 802.3ab 1000BASE-T
• IEEE 802.3u 100BASE-TX
Transmit Distance
• 10GBASE-T
  • 100M with Cat 6A or higher UTP
  • 50M with Cat 6 UTP
• 100/1000BASE-T
  • 100M with Cat 5 or higher UTP
Power
• Maximum Power Consumption: 8.04 W
• Input Voltage: 3.3 V
Data Transfer Rate
• Auto mode (support 100 Mbps)
• 1 Gbps
• 10 Gbps
Network Operation Mode
• Full Duplex (20 Gbps)
Interface Slot
• PCI Express x4/x8/x16 slot
Supported Functions
• 16 KB Jumbo Frame
• 802.1Q VLAN tagging
• Simple Network Management Protocol Agent
Driver Support
• Windows 8.1, 8, 7
• Windows Server 2008R2, 2012, and 2012R2
• Windows Hyper-V
• Linux kernel 2.6.x - 3.x.x
• VMWare ESXi 4.x - 5.x
Diagnostic LED
• Speed/Link
• Activity
Dimensions
• 133.3 mm x 121.9 mm x 21.6 mm
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Storage: 10% to 90% non-condensing
Certifications
• CE
• FCC
• C-Tick
Füüsilised parameetrid
Sertifikaadid
Sidustooted
DXE-810T PCI Express Adapter with 1 10GBase-T Port
Pildid
DXE-810T
Paremvaade
Eestvaade
Failid
Vaadake samuti
