Kiirotsing
Toote omadused:
BROADBAND INTERNET IP PHONE
Kirjeldus:
INTERNET PHONE MADE FOR HOME & OFFICE
The DPH-400S Broadband Internet IP Phone allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network (VoIP) technology with advanced communication features, and is compatible with industry-wide phone services. This sleek designed IP phone gives you the advantages of VoIP, while retaining the same look and feel of a traditional desktop telephone.
SUPERIOR VOICE QUALITY
The DPH-400S IP phone incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference and speed dialing to make it convenient to dial out or answer phone calls.
SURF INTERNET WHILE MAKING INTERNET PHONE CALLS
The DPH-400S comes with two Ethernet ports, one to connect to a DSL or cable modem, or to your broadband router. In an office environment equipped, this port can also connect to a PoE switch and obtain power directly from the network, dispensing you of the need to hook the IP phone to an AC power outlet. Once connected and logged onto the Internet, you are ready to make and receive calls. In addition, this IP phone provides another Ethernet port for connection to your PC, so you can talk on the IP telephone while browsing web sites, send e-mail, transfer files and do other network tasks on your PC.
QUALITY OF SERVICE AND SECURITY
The DPH-400S supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides priority queues to streamline traffic so web browsing and Internet download will not interfere with voice traffic and degrade Internet phone quality.
NETWORK INTERFACE
DPH-400S: 2 10/100BASE-TX Ethernet Ports (1 to PoE LAN switch with 802.3af compliance, 1 to PC)
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
