DVG-5402SPEOL EOS
Kirjeldus
INTERNET PHONE MADE FOR HOME & SOHO
The D-Link DVG-5402SP VoIP Router allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network technology with advanced communication features, and is compatible with industry-wise phone service. This VoIP Router connects you to up to two ordinary phone sets to let you make phone calls. Router connects you to up to two ordinary phone sets to let you make phone calls. connects you to up to two ordinary phone sets to let you make phone calls.
SUPERIOR VOICE QUALITY
The DVG-5402SP incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
COMPLETE SECURITY
The DVG-5402SP supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides a lifeline phone port to relay your incoming and outgoing phone calls to PSTN in case when a power down occurs. This guarantees that your phone connection will always be available.
INTEGRATED 4-PORT ROUTER
The DVG-5402SP provides a convenient router function to permit multiple computers to share an Internet broadband line. With four integrated Ethernet ports, four computers can connect to the DVG-5402SP and use its built-in NAT/DHCP server functions to log on to the Internet.
Põhiomadused
Liidesed
SIP funktsioonid
- Anonüümsete kõnede blokeerimine
- Kõnede blokeerimine ja filtreerimine helistaja IP-aadressi järgi
- Kõne suunamine (kinni, ei vasta, tingimusteta)
- Kõnede ajalugu (kõnede staatus)
- Kõne hoidmine
- Kõne suunamine fikseeritud numbrile (Call park), (Call Retrieve) (Proxy toetus)
- Kõne suunamine (Proxy toetus)
- Ootekõne
- Helistaja nimi ja kõneaeg (FSK)
- «Mitte tülitada» funktsioon (Do not disturb)
- Blokeerimine Caller ID järgi
Häälestamine/Juhtimine
WAN-ühendus
Качество обслуживания (QOS)
NAT TRAVERSAL
