DVG-G5402SPEOL EOS
Kirjeldus
INTERNET PHONE MADE FOR HOME & SOHO
The D-Link DVG-5402SP VoIP Router allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network technology with advanced communication features, and is compatible with industry-wise phone service. This VoIP Router connects you to up to two ordinary phone sets to let you make phone calls. Router connects you to up to two ordinary phone sets to let you make phone calls. connects you to up to two ordinary phone sets to let you make phone calls.
SUPERIOR VOICE QUALITY
The DVG-5402SP incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
COMPLETE SECURITY
The DVG-5402SP supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides a lifeline phone port to relay your incoming and outgoing phone calls to PSTN in case when a power down occurs. This guarantees that your phone connection will always be available.
INTEGRATED 4-PORT ROUTER
The DVG-5402SP provides a convenient router function to permit multiple computers to share an Internet broadband line. With four integrated Ethernet ports, four computers can connect to the DVG-5402SP and use its built-in NAT/DHCP server functions to log on to the Internet.
Põhiomadused
Liidesed
- 2 x FXS porti RJ-11
- 1 x FXO port RJ-11 lifeline funktsiooni toetusega
- 1 x WAN port 10/100Base-TX RJ-45 automaatse kaabli polaarsuse tuvastamisega MDI/MDIX
- 4 x LAN porti 10/100Base-TX RJ-45 automaatse kaabli polaarsuse tuvastamisega MDI/MDIX
SIP põhiomadused
- Individuaalne kasutajatunnus iga pordi jaoks või ühine kasutajatunnus kõikide portide jaoks
- Helistaja identifitseerimine (Caller ID)
- Otse signaal IP-to-IP ilma SIP Proxy
- Numeratsiooni plaan (Digit Map) ja DNS SRV, SIP SRV telefoniraamat
- Numbri valimine E.164 (ENUM välistamise reegliga)
- Hot Line, Warm Line
- Interaktiivse häälvastuse seadistamine (IVR)
- Outbound Proxy
- SIP INFO
- Kolmepoolne konverents (Ad Hoc reziim, nõuab meediaserverit)
- Kõne peamised funktsioonid:
- Anonüümsete kõnede blokeerimine - Kõnede blokeerimine ja filtreerimine helistaja IP-aadressi järgi
- Kõnede suunamine
- Kõnede ajalugu
- Kõne suunamine fikseeritud numbrile (Call park) ja kõne hoidmisest maha võtmine (Call Retrieve) (Proxy toetus)
- Kõne suunamine (Proxy toetus)
- Kõne ootereiim
- Helistaja nimi ja kõne aeg (FSK)
- «Ärge häirige» funktsioon (Do not disturb)
- Caller ID järgne blokeerimine
Häälfunktsioonid - Reguleeritav jitter-buffer
- Automaatne tuvastamine ja hääle/faksi/andmete ümber lülitamine
- Auto Gain Control (AGC)
- Кodekid: G.711μ/A-law, G.729A/B/AB, G.723 (6.3/5.3 Кbit/s), G.726
- Komfortse müra genereerimine (CNG)
- DTMF tuvastamine ja genereerimine
- In-band või Out of band DTMF event
- Packet Lost Concealment (PLC)
- Hääle/faksi/modemi (kuni 33.6 Кbit/s) toetus IP peale
- T.30 fax bypass thought G.711
- T.38 real time FAX kuni 14.4 Кbit/s
- Voice Activity Detection (VAD)
- Caller ID tuvastamine ja genereerimine Caller ID: DTMF, FSK-BellCore, FSK-ETSI
Häälestamine/juhtimine - Automatic Provisioning (v.a. TR069/TR104)
- Web-kasutajaliides
- TELNET kasutajaliides
- Konfigureerimisfaili salvestamine ja taastamine Web-liidese kaudu
- Kõnede ajalugu (saadud, määdalastud, blokeeritud)
- Call Detail Record (CDR)
- Aja sünkroniseerimine vastavalt NTP (vaikimisi D-Link NTP-serveriga)
- Parooliga kaitsmine (Web-liides ja TELNET)
- Ping Test
- Tehase vaikeseadistuste taastamine
- SNMPv2 (v.a. TR069/TR104)
- Staatilised ja default marsruudid
- System status
- TFTP/FTP/HTTP-klient tarkvara uuendamiseks
- TR069/TR104 kliendi toetus (valikuline)
WAN-ühendus - Big Pond klient
- DHCP-klient
- PPPoE autentimine PAP/CHAP kaudu
- PPTP-klient
- Staatiline IP-aadress
Teenusekvaliteet (QOS) - DiffServ (DSCP) või ToS IP Precedence tagging (WAN)
- Kiiruse piiramine LAN pordil
- Kiiruse piiramine WAN pordil (64 Кbit/s samm)
- WAN-pordi prioriteedi järjekord: RTP esialgu
- 802.1Q ja 802.1P Tagging (1 VID VoIP-liikluse jaoks, 1 VID LAN-liikluse jaoks)
NAT TRAVERSAL - STUN-klient
- DDNS-klient
- Portide diapasoon SIP ja RTP jaoks
- Staatiline marsruut
Turvalisus - Sisseehitatud tulemüür
- IP-aadressite filtreerimine
- Filtreerimine portide baasil
- Filtreerimine MAC-aadressite baasil
- Virtuaalne server
- DMZ
- Denial of Service (DoS) rünnakutest kaitsmine
- MD5 autentimine SIP jaoks
- Kaks eesõiguste tase: Administrator ja User
- VPN Pass-through with Multiple Sessions (IPSec, PPTP, L2TP)
Traadita liides - 802.11 b/g standardid
- Kuni 64 klientide toetus
- Automaatne RF-kanalite valik
- Traadita turvalisus: ligipääsu juhtimine MAC-aadressite baasil, 64/128-bitine WEP-andmekrüpteerimine, WPA/WPA2 toetus
Indikaatorid - Power
- Provision/Alarm
- Register
- WAN Link/Activity
- LAN Link/Activity (4 porti)
- Phone (2 porti)
- Line
